low pass filter
millerman 3732
i have a kilpch ksw 15 it has a low pass filter the goes from 40hz to 120 hz where should i set the low pass filter and will it make any differance i cant seem to tell also the the low pass on my receiver is set to 80 hz what should i do
Casey
H/T: Epson 6500ub
Sony UBP-X800
Toshiba HD-XA2 (HD-DVD, CD)
Onkyo 805 (pre-amp)
Outlaw 7125
Polk RTi 10 (bi-amped)
Polk CSi5 (bi-amped)
Polk RTi6
SVS PB 12 plus/2
Velodyne SMS-1
TV Rig: Samsung 50'' 4k display
Polk Signa-1 Surround bar
H/T: Epson 6500ub
Sony UBP-X800
Onkyo 805 (pre-amp)
Outlaw 7125
Polk RTi6
SVS PB 12 plus/2
Velodyne SMS-1
Post edited by millerman 3732 on
Check your receiver manual for the cutoff. If it doesn't say it in the spec, check in the bass management, sub out section, or under calibrationReceiver: harmankardon AVR235
Mains: polk R30
Center: polk CSi3
Rear Surrounds: polk R20
Subwoofer: polk PSW404
DVD: Panasonic DVD-S29 -
Like Mike stated, the manual will greatly aid you in setup of your receiver and speakers.
Where you should set it however is an entirely different matter as most of us have to find that sweet spot for ourselves. If your receiver allows you to set a filter (crossover) for the sub you should disable that and just allow the sub to set its own frequency (for you to manually adjust). A good starting point on where to set your subs crossover (40-120) is the same crossover point you set your main speakers to. For instance, if all your speakers have frequency responses from say 50Hz-20kHz a good starting point would be to set their crossovers in the receiver setup for Center, L/R, Surround L/R at 60Hz (so they dont try to play anything lower than that) notice how I added 10Hz; its just a margin for error. After that you should use a Sound Level Meter from Radio Shack and the receivers test tones to calibrate your system. But read your manuals completely as it will probably explain in much more detail how to accomplish this. -
Miller, since you say that your receiver is doing a 80Hz low-pass to the sub, that means that it's handling the bass management duties and that the sub's internal crossover isn't needed in most cases and might just interfere with the receiver's crossover. Your KSW-15 has an LFE input which should be used and which then completely bypasses the internal sub crossover. If you've already got the sub output on your receiver connected to the sub's LFE input, that might explain why you can't tell any difference when you change the crossover setting on the sub; it's been bypassed and doesn't do anything.
