Amp Q's Stacking / setup
disneyjoe7
disneyjoe7 Posts: 11,435
edited July 2005 in Electronics
The setup Onkyo 898 as pre/pro driving 2 Halo A23 bridged mono amps feeding RT150i's front.
Question 1,
Can these amps be stacked one on top of the other?
Question 2,
Using the Onk as the pre/pre for both 2ch and HT is it best to balance the front amps (A23) set as 0 in level calibration on AVR. This causing the setup to be the following...
Left 0
Center +5
Right 0
Surround Right +8
Surround left +2
This seems to work best in 2 ch being this level setup also changes direct / pure audio modes.
Vs.
Left -8
Center -3
Right -8
Surround Right 0
Surround Left -6
Subwoofer setup didn't change either way in AVR set as -5 changed on sub volume control.
Speakers
Carver Amazing Fronts
CS400i Center
RT800i's Rears
Sub Paradigm Servo 15
Electronics
Conrad Johnson PV-5 pre-amp
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Sony CX400 CD changer
Panasonic 42-PX60U Plasma
WMC Win7 32bit HD DVR
Post edited by disneyjoe7 on
  • disneyjoe7
    edited July 2005
    Is this a Duh?
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
  • Frank Z
    Frank Z Posts: 5,860
    edited July 2005
    Guess it depends on the amount of heat being generated and the manufacturers recommendations. Personally I would keep them seperated.
  • disneyjoe7
    edited July 2005
    Thanks Frank,
    Question about Parasound below.
    Quote from Parasound.
    Do not stack the A23 with other components inside a cabinet unless you use a fan to circulate and exhaust the warm air that builds up between them.
    Also there's this you can rack them optional brackets and taking the feet off so that there is 1 3/4" space. So why no fan needed in a rack?
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
  • Frank Z
    edited July 2005
    I'd have to guess that most cabinets include a door up front and a rear wall, thus traping a great deal of heat. A rack on the other hand is generally open on all sides and that allows for greater heat dissipation.
  • disneyjoe7
    edited July 2005
    Frank,
    Ok I never considered that a rack is open at rear also in front vs. a cabinet.
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
  • Frank Z
    edited July 2005
    You're welcome.
