Time to change stuff out.
1996blackmax
1996blackmax Posts: 2,436
edited July 2005 in Car Audio & Electronics
A couple of bad things happened recently to some of my components.
My Kicker ZX460 is finally showing its age. The left rear channel cuts out. It has to do with the plug in module port. I can get it to work again if I move the module on the module docking port, but it cuts out again. I do not feel like fixing it so I bought an MTX Thunder 564 to replace it. I got a good amount of use out of the Kicker (bought it in 1997), but the time has come to part with it :( .
Also my Kicker Resolution Components had to come out as well. These are the older Resolution Components that were around the same time I bought my amp. So I also got a lot of years out of them too. The tweeter was cutting out sometimes, the mid would play the whole time. I took the door apart and all the connections were secure, so it has to be the tweeter :( . Luckily I still have my old Polk DB3065 components :D . I will probably be picking up a set of coaxials for my deck pretty soon to replace the old Polks I have back there.
Alpine: CDA-7949
Alpine: PXA-H600
JL Audio: 10W6v2 (x2)
KnuKonceptz
Second Skin
Post edited by 1996blackmax on
  • neomagus00
    neomagus00 Posts: 3,899
    edited July 2005
    isn't getting new stuff fun? :D
  • 1996blackmax
    edited July 2005
    Sure is :D . Can't wait to install it!
    Alpine: CDA-7949
    Alpine: PXA-H600
    KnuKonceptz
    Second Skin
  • 1996blackmax
    edited July 2005
    It is installed and I am :D .
    Alpine: CDA-7949
    Alpine: PXA-H600
    KnuKonceptz
    Second Skin
