Upgrade sub
DaveSal
I've got a GNX104 (single v/c 10") sub hooked up to an alpine MRP M350 1-ch/200 w RMS 4 ohm amp. The sub is okay, but leaves a lot to be desired at higher volumes. Would substituting a momo 10" enable me to play a bit louder w/out disortion? I'm mainly interested in SQ. I don't really play all that loud -- moderate-to-high volume is where my existing sub starts to distort. Also, would momo single or dual voice be a better choice? The alpine puts out around 350 w rms into 2 ohms.
Pioneer 880PRS
Polk C300.2
MB Quart PCE 216
Alpine MRP 350
Polk GNX 104
Polk C300.2
MB Quart PCE 216
Alpine MRP 350
Polk GNX 104
Post edited by DaveSal on
I had the same sub you do a few months ago & switched it out for a Eclipse 8112svc & its MUCH better. I paid $139 brand new I believe on ebay since they are the model previous to the one thats out.
yes, moving up to a momo will provide better sq at a higher maximum volume - significantly so, i believe, since you're moving from a gnx.
vc's - since you're running a single sub, you'll want the DVC; you'll wire the coils in parallel to get a 2-ohm load. note, however, that 350 is over the momo's powerhandling by a decent amount. momos HATE overpowering, so you'll have to be careful to set the gain properly. do that, and i think you'll be quite happy.
if you don't mind moving away from polk, give us a budget and we can help you decide on a woofer.It's not good, very fundamentally simply not good. - geolemon
Thanks for the advice. I may want to try the MOMO sub (w/proper gain adjustment), but would be interested in any suggestions you might have for a non-Polk spkr. I'd be looking to keep the price below $150. Also, I'd like to try to keep my existing enclosure -- .65 -- if possible.Pioneer 880PRS
Polk C300.2
MB Quart PCE 216
Alpine MRP 350
Polk GNX 104 -
I have a Sound Splinter sub in my car right now. Might be something you want to look in to. I am very happy with how it sounds. The amp that you are runnig would make a nice combo with this sub. My Kicker amplifier is putting out around 360 watts RMS to it.
It is a little more that the $150 you want to spend, but for $169 you get a lot of speaker for the money.
http://www.soundsplinter.com/rli_series/rli_10_inch_DIY_car_and_home_subwoofer_driver_information.html
http://www.soundsplinter.com/rli_ignition_series_8_inch_and_10_inch_diy_subwoofer_drivers.htmlAlpine: CDA-7949
Alpine: PXA-H600
JL Audio: 10W6v2 (x2)
KnuKonceptz
Second Skin -
sorry, other people are gonna have to help on this one... i'm not so good at the 150 price range...It's not good, very fundamentally simply not good. - geolemon
ID v3
How about the JL 10w3v2? Looks like it would be a good match for my amp in terms of power. Is anyone familiar with its performance?Pioneer 880PRS
Polk C300.2
MB Quart PCE 216
Alpine MRP 350
Polk GNX 104
