Opinions on Sony STR-DE897
  • RuSsMaN
    RuSsMaN Posts: 17,986
    edited July 2005
    Wussies.
    I bet Jesse started posting quotes from some obscure website, then Mark retorted with religious and ethnic slurs. At least thats what I'm hoping.
    Couple of nice receivers, btw:
    Magnum/Dynlab MD-208
    Music Hall Maven
    F1nut Posts: 51,786
    edited July 2005
    No, No and No.
  • shack
    shack Posts: 11,154
    edited July 2005
    Originally posted by RuSsMaN
    Wussies.
    Nah...they probably just took off their pants and started doing the Hokey Pokey..."That's what it's all about."...
  • dorokusai
    dorokusai Posts: 25,576
    edited July 2005
    Actually it was an open display of affection that got way out of hand....Jesse is a charmer you know ;)
    heiney9 Posts: 25,440
    edited July 2005
    Originally posted by F1nut
    Oh boy! :rolleyes: There isn't a receiver or AVR made that will come anywhere close to overkill for a 2 channel set up. If you had a killer 2 channel set up you'd quickly realize that it's much better than surround sound.
    Absolutely true!!!!
  • Toxis
    Toxis Posts: 5,116
    edited July 2005
    I thought the same last night... :p
  • shiu
    shiu Posts: 169
    edited July 2005
    Originally posted by Mike682
    I was reading this also...
    The Sony just dies out fast with all channels driven
    Sony test report:
    1/2 channels: 141/122 watts (21.5/20.75 dBW)
    5/7 channels: 35/31 watts (15.5/14.75 dBW)
    OUCH!! a 6db drop!! with all channels driven
    Mike, I subscribe to the S&V mag and I read the above also but I thought it was for a DE698.
    eluth was talking about the Sony STR-DE897. S&V also reviewed the DE897 in the Sept 2004 issue. It beats the Yamaha RX-V750 in noise level, 1/2 channel into 4 ohms, 5 channels into 8 ohms and has lower THD at 1W. Results and links are as follow:
    STR-DE897
    1/2 channels: 149/128 watts (into 8 ohms)
    1/2 channels: 227/181 watts (into 4 ohms)
    5 channels: 76 watts (into 8 ohms) vs RX-V750's 61 watts.
    The 2 channel measurements were for both channels driven at the same time.
    These numbers are obtained as usual with a 1 KHz signal at clipping but they tested the Yamaha and the JVC the same way. You just have to discount those numbers somewhat for 20 to 20 kHz. T
    Here's the reviewer's comments:
    "The Sony STR-DE897 is a fine value at its list price, let alone a discounted one. The remote is smaller and a bit more crowded than the others, but the layout is sensible and easy to follow. If simplicity was one of the chief design goals for this receiver — which seems to be the case — then Sony has hit the nail on the head."
    Links:
    http://www.soundandvisionmag.com/article.asp?section_id=5&article_id=658&page_number=3&preview=
    http://www.soundandvisionmag.com/assets/download/receiverlab0804.pdf
    Not trying to defend Sony, I don't own one anyway but since I read both reviews (including the one you quoted) I thought its fair to post the one eleuth was asking about.
    IMO, for $200, the DE897 offers good value, for someone who just want to watch movies with DD/DTS 5.1 without spending much. Since eluth's focus is Stereo music, he may be better off going with something higher end.
