Single or multiple power supplies in Amp
jim v.
Would a power amp sporting a single large power supply (toridial) (ATI-1500) or would an amp having 5 power supplies be better (bryston 9B) for clarity, soundstage etc.
You would think 5 smalls would run cooler than 1 large, but I really have no idea. So why did I post this, once again I have no idea!
Oh, the bottle has been to me, my closes friend, my worse enemy! -
Individual is always better. You won't get interaction between the channels (noise, interferece, etc.) and the other channels won't be able to rob power from each other.
Aaron -
Ya! Aaron, that's what I was trying to sayOh, the bottle has been to me, my closes friend, my worse enemy!
as long as the power suply has enough power and is good qualty i dont thaik it would matter that much the problem you would have is when you draw curent and your power suply can prduce enough your voltage goes down like in a car when the bass hits your lights dim now when the voltage dims the power output drops I=V/R ohms law and power=I^2R now you crank it up and your amps over draw the power on 1 chanel it can afect the others but if you have seperate ps 1 chanel wont efect the others
