A question about amplifiers
Mike682
Mike682 Posts: 2,074
edited July 2005 in Electronics
Eventually I am gonna get into seperates. As I was thinking about which amps to look at, I wondered if seperate amps should be matched with regard to wattage.
For example, If I run a 3ch amp for the fronts and another 2ch amp for the rears should they all have the same wattage rating?
I know surrounds arent that demanding when compared to the fronts and center. So could I get away with having a lower wattage amp for the rears?
Thanks a lot
Mike
Receiver: harmankardon AVR235
Mains: polk R30
Center: polk CSi3
Rear Surrounds: polk R20
Subwoofer: polk PSW404
DVD: Panasonic DVD-S29
Post edited by Mike682 on
  • Early B.
    Early B. Posts: 7,900
    edited July 2005
    Doesn't matter. Watts don't mean squat.
    Now that I got that off my chest, buy as much power as you can from the best quality amp you can afford, especially for the front soundstage.
    "God grooves with tubes."
  • Gaara
    Gaara Posts: 2,415
    edited July 2005
    I wouldn't worry about it. All you have to do is make sure your speaker levels are set correctly and your all set.
    I personally have 600 watts going into my main 5 speakers, and 200 going into my back surrounds, and have never had a issue. For a while I had 200 watts for my fronts and around 135 for the rest, again no problems.
    Jared
  • aaharvel
    aaharvel Posts: 4,489
    edited July 2005
    all of the above +1.
    Adcom 5300 powers the front L&R- 80x2
    Adcom 7300 powers the center, side and rear surrounds- 60x5-
    and it sounds perfect.
    H/K Signature 2.1+235
    Jungson MagicBoat II
    Revel Performa M-20
    Velodyne cht-10 sub
    Rega P1 Turntable
    "People working at Polk Audio must sit around the office and just laugh their balls off reading many of these comments." -Lush
  • Mike682
    edited July 2005
    Excellent....that's what I thought
    Thanks for the responses
    Mike
    Mains: polk R30
    Center: polk CSi3
  • unc2701
    unc2701 Posts: 3,587
    edited July 2005
    +1 on the different power- here I've got 125w to the center & rears, 300 to the fronts. Also, if you get amplifiers from the same maker/ line (like aaharvel w/ the adcom x300's or me w/ the bryston SST's) you typically won't even have to tweak the levels too much w/ an SPL meter.
    Backburner:Krell KAV-300i
  • Mike682
    edited July 2005
    Very good point about the speaker levels.
    Mike
    EDIT: oh....does unc in your username stand for University of North Carolina???
    Mains: polk R30
    Center: polk CSi3
  • unc2701
    edited July 2005
    yep, did undergrad & grad school there... You NC local, too?
  • Mike682
    edited July 2005
    No...but by best friend Marc did undergrad and grad (MPA) there also. I've been down there a couple of times and had a blast. He was in the chi psy (spelling?) frat.....
    did you ever go to top of the hill, carolina brewery , etc
    Also another bar (forgot the name) was upstairs and you could go outside in the back...they had a stage with local bands playing...
    Great...Great times there
    Mike
    Mains: polk R30
    Center: polk CSi3
  • unc2701
    edited July 2005
    hehe... if it's in chapel hill & serves alcohol, I've been there, puked in the bathroom, and lit fires in the street in front of it.
  • aaharvel
    edited July 2005
    go roy. GO HEELS!
    Revel Performa M-20
    Velodyne cht-10 sub
    Rega P1 Turntable
  • Mike682
    edited July 2005
    Originally posted by aaharvel
    go roy. GO HEELS!
    I was happy for Roy and happy for UNC that they were able to turn it around after Doherity got the boot
    At least Roy can coach and recruit...unlike that wacko Doherity
    Mains: polk R30
    Center: polk CSi3
