best amp for mm120?
Systems
what is the best amp for 2 mm120's?
Testing
Testing
Testing
Testing
Testing
i would go with the rockford fosgate bd1000.1
or something from mtx
-cody -
If I was you I would stay away from Rockford. Try the JBL BP1200.1. It puts out 1,200 watts into 2 Ohms, and if your electrical system is good enouf it can put out 1,375 watts with 14.4 volts. Plus you can get one at www.crutchfield.com for $400. I plan on running a pair of Didgital Designs 9512 with a pair of these amps. These amps are great and way more dependable than Rockfords.
rockford fosgate is very reliable and you dont have to worry about your electrical system because they are very efficient too
-cody
