Directional arrows on cables?
    heiney9 Posts: 25,431
    edited July 2005
    madmax wrote:
    So if I read this correctly... it is your opinion that sound differences are possible but if the rest of a system isn't up to it then it is not worthwhile to spend additional big dollars on cables because you wont hear it?
    madmax
    Yes, that’s basically what I’m stating as my opinion. If you have a cheap receiver, cheap speakers and cheap CD player why spend a couple hundred bucks on cables. Makes no sense…take that money and spend it on the components until you have a system that might benefit from upgraded cables. You will certainly get more benefit from buying higher grade components than you will using low grade components and high dollar cables. It’s been said here before…it’s all about the synergy and all the pieces working together to the benefit the whole.
    It would be less than ideal to own a Conrad Johnson amp and use “out of the box” patch cords to connect to the pre. Just as it would be silly to own a few hundred dollars worth of components and use a few hundred dollars worth of cables to connect them with. It’s not my intention to reduce this to a $$$ issue, it’s just the best way to get my point across. Cables are always going to have a sonic signature…can differences be heard? depends on your system, your ears and your belief. Unfortunately the cable/interconnect industry has made it very hard to discern between the truth and the sales pitch, and that’s where much of my personal skepticism comes from.
  • dorokusai
    dorokusai Posts: 25,576
    edited July 2005
    I'm wondering how many times we're going to comment on the directional arrow on a interconnect? This was explained awhile ago....or is everyone just on drugs?
    In addition, Bruce Brisson didn't design Monster Cable as Noel Lee is actually quite educated. MC used a few of Bruce's designs in their cables, not the other way around.
  • dragon1952
    dragon1952 Posts: 4,907
    edited July 2005
    Well the only reason I brought it up again was because what was stated in the two comments I posted hadn't been stated before in that way. That the arrows (if used to indicate which direction the ground is) should all point to the load, not necessarily in the same direction throughout the system.
    edited July 2005
    Seems to me we were able to squeeze out just a little bit more info/opinion. Geez, I didn't know there was a limit on how much/many times we could discuss something. Overkill is the theme around here most of the time ;)
    Damn looks like I just added to this thread again :eek:
    P.S. for the record I wasn't commenting on the direction of the arrows :p
  • dragon1952
    edited July 2005
    Maybe they should be painted in Glo-paint and point the way to the bathroom in case you're watching a movie in the dark.
  • bknauss
    bknauss Posts: 1,441
    edited July 2005
    Directionality of cables is BS (well, typical cables at least). If the designers of military grade equipment don't worry about which way they point their cables, then we sure as heck shouldn't worry about it.
    Now cables like some MITs have a circuit in them, so hooking them up backwards would be bad.
    Brian Knauss
    ex-Electrical Engineer for Polk
  • disneyjoe7
    disneyjoe7 Posts: 11,435
    edited July 2005
    BS I say not, in the Telecommunication sector of the world. The ground in on the source side only, on important signals like clocking and such.
    Speakers
    Carver Amazing Fronts
    CS400i Center
    RT800i's Rears
    Sub Paradigm Servo 15
    Electronics
    Conrad Johnson PV-5 pre-amp
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
    Sony CX400 CD changer
    Panasonic 42-PX60U Plasma
    WMC Win7 32bit HD DVR
  • dorokusai
    edited July 2005
    MIT networks are passive, and you won't harm anything by using them backwards.
    How can you compare a military grade connection to a consumer grade connection? You're just generalizing, as their are more variables than a ground wire termination in the construction of any type of cables and/or connections.
  • bknauss
    edited July 2005
    I was saying you shouldn't hookup MITs backwards because, if I remember correctly, they're more or less an RLC filter... and you won't get the same response forward and backward.
    And yes, it was a huge generalization. It would take a couple pages to go in depth into each sector of business that uses cables and their practices.
    And yes, I did overlook grounding techniques. Oops... these types of posts pop up when you've been painting a house for several hours and its late at night :)
    Brian Knauss
  • dorokusai
    edited July 2005
    Painting? Ugh, I hate painting.
    As far as the MIT, I just meant you wouldn't blow anything up by hooking them up backwards.
  • disneyjoe7
    edited July 2005
    So if I connected / broke in a set of AudioQuest Diamond backs backwards, I thought that the arrow was the direction of signal flow not the ground end. :(
    Should I now reverse them or forget it.
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
  • disneyjoe7
    edited July 2005
    Ok, I'm not trying to be an A$$ ok. I know to feeling is that it doesn't make any difference, but I ask because of some noise at times so this may be my problem. So if a cable is broken in one direction can you re-break it in the other direction?
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
  • madmax
    madmax Posts: 12,434
    edited July 2005
    Whether it really makes a difference or not you should shoot for the proper orientation.
    Remember, a good system doesn't always sound better with the addition of one tweek. It is the combination of multiple tweeks that really makes the difference. (I stole that remark from F1Nut).
    madmax
    Vinyl, the final frontier...
  • dorokusai
    edited July 2005
    Audioquest uses that arrow for more than a grounding reason, so from their perspective use the arrow as it is defined by Audioquest....signal flow. They also say that a cable can change state if it is unused, thus it can "break-in" or "adjust" again. Just go with the signal flow idea, and don't worry about it anymore.
  • disneyjoe7
    edited July 2005
    Thanks guys,
    I will keep the Audioquest Diamond Back cables in the direction I have them in. The Arrow is facing the signal way, so on AQ cables the arrow is not for the ground end?
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
  • bvette94
    bvette94 Posts: 356
    edited August 2005
    Imo i think the cable is designed in a fashion to keep out interfearence. The way the wires are twisted. if you plug all of your cables in the direction that the arrows show any innerfearence would deflect out and away from the cable. It would be like sticking two magnets together. sort of like the telephone cat 5 wiring principle. IF you wire your system like this it is one less source of interfearence or unwanted noise.
  • PolkThug
    PolkThug Posts: 7,532
    edited August 2005
    Just make sure that if you move south of the equator, to re-twist the wires in the opposite direction.
  • bvette94
    bvette94 Posts: 356
    edited August 2005
    yea that is helpful.
  • dragon1952
    edited August 2005
    If you read the previous posts you would have found that sometimes the arrows are to reference the ground, sometimes just informational for those that wish to connect them the same way everytime and sometimes because the manufacturer states that their design is optimal if the same direction is always maintained. Directionality, as it pertains to interference rejection, is immaterial for unshielded cables. Twisting can help with interference but an unshielded cable using twisting for RFI rejection is non-directional. How can an unshielded cable that uses twists possibly be directional? It's exactly the same in both directions. You can't make a general statement like that regarding arrows when there are multiple reasons for putting them there in the first place. You have a lot of nerve dissing Polk Thugs remark. You can't even spell interference correctly let alone the same way twice :rolleyes:
  • bvette94
    bvette94 Posts: 356
    edited August 2005
    Thank You for correcting me. i will not make any more wrong opinions or spell any words wrong again. I am sorry. You guys are so smart.Thanks for pointing them out. Next time i will do my homework before i try to get involved with chats regarding things i dont know anything about.
  • polksda
    polksda Posts: 716
    edited August 2005
    I connected some interconnects with the signal going in the opposite direction from the way it was marked on the cables, and my microwave exploded.
  • dorokusai
    edited August 2005
    Lol :D
  • Polkersince85
    Polkersince85 Posts: 2,883
    edited August 2005
    What happens if you use the red one for the left channel?
