polk mm100 question
martijn
Hello,
How much air space would i need for my polk mm100
I have space for a box of (see attach), is this enough?
Are there such things as Momo Grills for 10" Subs? If so.. where can i get them or can you tell me of there are grills from another brand that will fit?
Thank you,
Martijn Poortier
Thank you,
Martijn Poortier
Post edited by martijn on
the specs are on this website--just look up the mm100 in the store then click on specs
multiply your length, width, and height and there you go...
-cody -
Use this web site to figure the air space. www.the12volt.com
