What component got high SPL?
NOISESTEEL
Hi, i got a system with high SPL (MTX 1501D + MTX T9515 4+4) and need any kit to make my stereo with high volume and SPL. It will be played in my Precision Power PC650 (6 channels), i will use 2 bridges 200W RMS for each.
I'm thinking and i liked the db6500 and MMC6500 (in that order).
So, i need sugestions to safe my stereo.
Thanks a lot!
PS: Sory, my english is not good.
Thanks a lot!
Project: HU 860MP, MB quart PCE 216 (ser
Post edited by NOISESTEEL on
The Momo is a better built speaker and will handle more power and so it will sound better loud. Get the Momo.polkaudio sound quality competitor since 2005
Humm so mm6 is powerfull. But it can be played with 200 W RMS each kick panel, with no problems (course, no distortion in osciloscope)? I know, most pples here use components speakers in door...but anyone have simulated mm6 in kick panel (floorstanding)?
Any other sugestion in components speakers (high sensivity, Qts, durability, low Fs,...high power!)
Thanks a lot! FernandoProject: HU 860MP, MB quart PCE 216 (ser -
my old mm6s handled 225 for about 3 years before i started popping the leads off the terminal...
You could just give them the 150 they require and they would be plenty loud enough. The db difference between 150 adn 200 watts would probably not be able to be noticed. Plus youre speakers would last longer.polkaudio sound quality competitor since 2005
+1, I've got the MMC6500s being installed tommorrow and they'll be driven by a Phoenix Gold R4.0:2 with about 125 wpc@4ohms and 200 @2ohms. I'm sure that'll be most ample."SOME PEOPLE CALL ME MAURICE,
CAUSE I SPEAK OF THE POMPITIOUS OF LOVE" -
yea but then you wont have an excuse to upgrade:D
