A new AC power cord I made up.
disneyjoe7
Something I seen on this forum while doing a search one day gave me some ideas.
So I'm going to do this to my UPS as for as wiring / outlets / IEC connections. See here if you haven't yet....
http://clubpolk.polkaudio.com/forum/showthread.php?s=&threadid=29923
This wiring thing was all new to me so to get my feet wet so to speak, I made this up first.
Speakers
Carver Amazing Fronts
CS400i Center
RT800i's Rears
Sub Paradigm Servo 15
Electronics
Conrad Johnson PV-5 pre-amp
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Sony CX400 CD changer
Panasonic 42-PX60U Plasma
WMC Win7 32bit HD DVR
Post edited by disneyjoe7 on
Speakers
CS400i Center
RT800i's Rears
Electronics
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
WMC Win7 32bit HD DVR -
I finished the end's with Marinco Hospital 15amp plug & IEC connector.
Using this on my Halo A23 amp powering RTi150's.
Over all sounds really sweet, cleaner noise is lower. Bass seems deeper, the highs seem more pronounced as the noise is lower then before. I can't wait till I get my UPS done.
Speakers
CS400i Center
RT800i's Rears
Electronics
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
What kind of wire did you use and how come you have two grounds? I've never actually tried an aftermarket / diy creation powercord so making one for myself would be a cheap way to try one out.
Sorry the wire is 12g stranded, 2 grounds, 1 hot, 1 neutral.
Wired as H G G N start by crossing to the right Ground over the other Ground, thus bringing both Grounds to the outside. Then cross Neutral to the right over Hot thus bringing Grounds to the inside. Over and over again, I don't know for sure why this seems to improve the sounds / noise levels. Larger copper more amps, wire crossed over and over again canceling noise in AC line? Maybe.
Speakers
CS400i Center
RT800i's Rears
Electronics
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Cool. I'm not sure what wire you used but it may need to burn-in and smooth out.SDA-2a, Anthem Pre-2L, Anthem Amp 1, MF A324 DAC, Rotel RCD1070
Senn HD650 Cardas, Mapletree Audio Ear+ HD2, Kimber KS1030, Bel Canto DAC2, M-Audio Transit, Laptop. -
Cool... I just might have to snag some wire and connectors next time I'm at a home depot or princess auto. Thanks for the info and let us know if it sounds the same after a week or two (burn in making a difference or not?)
Michael_w and Dcarlson,
Here to report back Wire is Home Depot 12g stranded 600v wire. I say its AC power cable not audio cable in anyway.
Speakers
CS400i Center
RT800i's Rears
Electronics
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
If you have noise in your AC line, a cord like that would work to cancel it because of the crossing?
This noise I found was in the CD player paused, volume up all the way with ear close to tweeter you hear some white noise. I made this power cord up and one of the things I noted right away was that this noise was lower with this cord over the stock cord.
Odd maybe, maybe not?
Speakers
CS400i Center
RT800i's Rears
Electronics
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
