Multi zone?
mrmusicman
I'm trying to add two speakers on my patio for a second zone.I'm not using the amps in my H/K as its duties are pre/pro,my set -up is 5.1 and my outlaw amp is only 5 channel in my main system.My H/k manuel says I need a seprate amp for a second zone, does anybody have any ideas as how I can use the amps in the h/k as a second Amp?There is a place on the rear of the H/K to connect an external amp via 2 rca jacks labled multizone.
Mike
Mike
Outlaw 990 Processor
Outlaw 755 Amp
Denon 2900 dvd-sacd
Dishnetwork HD-Dvr
55" Sony LCD RPTV
Lsi 9-fronts
Lsic-center
Rt55i- surrounds
Velodyne cht-10 sub
2007 Dodge Quad cab
Kenwood Excelon KDC-X891
JL Audio 300/V2
Polk Audio SR 6500 - Fronts
Polk Audio DB651 - Rear
2 -10" Treo Subs
Interfire IB 2600C sub amp
Sirius Sat radio
Ipod connection
Outlaw 755 Amp
Denon 2900 dvd-sacd
Dishnetwork HD-Dvr
55" Sony LCD RPTV
Lsi 9-fronts
Lsic-center
Rt55i- surrounds
Velodyne cht-10 sub
2007 Dodge Quad cab
JL Audio 300/V2
2 -10" Treo Subs
Sirius Sat radio
Ipod connection
Post edited by mrmusicman on
Not without modifying your receiver. Thus in turn maybe turning a perfectly fine pre/pro to a large paperweight or small boat anchor. I wouldn't do it with some decent inexpensive amp's on the market.
Speakers
Carver Amazing Fronts
CS400i Center
RT800i's Rears
Sub Paradigm Servo 15
Electronics
Conrad Johnson PV-5 pre-amp
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Sony CX400 CD changer
Panasonic 42-PX60U Plasma
WMC Win7 32bit HD DVR -
Hook them to the left and right mains. But thet will play as loud and when your playing the main zone. I don't think it's possible with your AVR.
But you probably don't need to have alot of power for the patio. DJ7 is right. -
Thanks for the replys,I tried hooking them to the front channels and there was no way to isolate them unless disconnecting the patio speakers when I watch a movie.I know the newer H/k models that are 7.1 your able to use the extra surround channels if your main zone is 5.1.I guess its time to consider another up-grade.Overall I've been happy with this H/k but my next up grade will not be a reciever.:DOutlaw 990 Processor
Outlaw 755 Amp
Denon 2900 dvd-sacd
Dishnetwork HD-Dvr
55" Sony LCD RPTV
Lsi 9-fronts
Lsic-center
Rt55i- surrounds
Velodyne cht-10 sub
2007 Dodge Quad cab
JL Audio 300/V2
2 -10" Treo Subs
Sirius Sat radio
Ipod connection
