momo 6.5 compents cross over help
Systems
tweeters are popin like there not crossed over at all they sound horrible maby i wired the cross over wrong anyone had this poblem?
Testing
Testing
Testing
Testing
Testing
I have heard one guy complain that the tweeter cone was hitting the grill. If this is the case you should contact Customer Service and see how they want to handle it.
But you should check that you have your tweets crossed over correctly.
Easiest way is to disconnect the tweeter output from the crossover and see if they stop playing.
I doubt you had them reversed as youd notice pretty quickly if your mids were only playing from 2600 Hz and up!polkaudio sound quality competitor since 2005
