Good setup or not?
Mendo
Mendo Posts: 13
edited July 2005 in Car Audio & Electronics
Alright guys I have almost decided on what I’m putting in. Again I’m the one with the 97 Dodge Neon. Ok here is a list of what I am thinking of.
• Kenwood KDC MP7028 HU
• Polk MMC6500 components
• Polk C300.2 2/1 Channel amp to power components
• Polk MM2104 subs x2
• Polk C500.1 Monoblock amp to power both subs
I was just wondering how well this would work.
Also
If I’m just going to use the two amps how many preamp outputs would I need. I was also wondering if this is a good HU for the money. I am a little hesitant with it because of the price so if I don’t need 3 preamp outputs the I’ll look for something different.
here's the site for the HU http://www.crutchfield.com/S-PwfJaGZYB9J/cgi-bin/ProdView.asp?i=113MP7028
Post edited by Mendo on
  • MacLeod
    MacLeod Posts: 14,358
    edited July 2005
    That looks perfect. Those amps are near perfect matches for those speakers.
    As for pre-outs, you only need 2 with this setup but you should try to get one with 3. This will allow you room to upgrade if you wish to do so in the future. Plus a subwoofer level control is a little different from a fader and kinda works better.
  • Mendo
    Mendo Posts: 13
    edited July 2005
    where would be a good place to put the tweeters in my car
    should i look at getting a couple of kick panel enclosures or is that just a waste of money
    and are there any web sites that i should stay away from when purchasing online
  • audiobliss
    audiobliss Posts: 12,518
    edited July 2005
    Man, that is an awesome set-up!! You'll be happy with that for life! I'm not real fond of Kenwood stuff, but that looks like a pretty nice HU!
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    Klipsch RF-35, RB-51ii
    [Car Audio]
  • audiobliss
    edited July 2005
    Well, make sure the retailer is authorized! That's a biggie! As for where to put the tweets, I'm not that familiar with Neons. I'll see one Tuesday, so I'll peep in and see what I can find out. I'd try to do something other than kick-panels. There are several cons to using them, and they're not that cheap. You can probably find something better.
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    [Car Audio]
  • Mendo
    Mendo Posts: 13
    edited July 2005
    thanks all the help is greatly aprieciated
  • Mendo
    Mendo Posts: 13
    edited July 2005
    another question
    what is the difference between the MM2104 and the MM2104DVC subs?
  • Toxis
    Toxis Posts: 5,116
    edited July 2005
    single or dual voice coil for wiring configurations. You'll want the single so you can get a 2 ohm load out of the amp.
  • MacLeod
    edited July 2005
    The only cons to using kick panels is that they eat up some of your leg room and in a Neon you aint got much to start with.
    But they put the speakers at a more equal distance to your ears then having one in each door with one twice as close as the other. This put the image right in the middle of you where it should be.
    Sounddomain.com and Crutchfield.com are the best places to buy. They are fully authorized dealers of the stuff they sell and have excellent reputations. Sounddomain is a little cheaper tho. You can find sites with cheaper prices but if you buy something from an unauthorized dealer you cant be sure what youre getting. Could be remenufactured, repaired or an outright knock off!
  • AustinKP
    AustinKP Posts: 861
    edited July 2005
    Sounddomain.com does pricematch though. Even to unauthorized dealers. Even if they can't match, they'll ususally drop their price a ton...
    http://www.silverdragon.com/punkie/cybertusk/net.idiot.html - Read it, know it
    Alpine 9815
    Ascendant Audio Atlas 12
    2 Gallons SecondSkin Spectrum V.2
  • Mendo
    Mendo Posts: 13
    edited July 2005
    need some more help please. I was originally going to go with the Kenwood KDC-MP7028 but after searching around some more I have found another that looks good too, the Panasonic CQ-C9700U. The only thing that concerns me is the RMS Power Bandwidth on the Panasonic. I don’t know what the number is supposed to be but it’s at 1k while the Kenwood is at 30-20k. just wondering what one I should use. Thanks
    http://www.crutchfield.com/S-1BDXe9xo9oX/cgi-bin/prodcomp.asp?g=62700&ITM133C9700=on&ITM113MP7028=on&hidesimilar=n
  • audiobliss
    edited July 2005
    When I first saw that, I didn't have a clue what it meant. However, I clicked on it on Crutchfield's page, and they describe it as being the frequency (or frequency range) at which the HU's internal amp's RMS power output was measured. Thus, the Panasonic was rated as putting out it's advertised RMS power at 1,000Hz, while the Kenwood was rated as putting out it's advertised RMS power at 30Hz-20,000Hz.
    If you were actually comparing the amps of the two HUs, you would definitely not want the Panasonic. Since it's rated at 1,000Hz, it probably doesn't make near it's advertised RMS power throughout the entire frequency range (which is where your music is). However, this shouldn't really matter too much, as I believe it only reflects on the amp (and the manufacturer), and not its pre-amp section. Since you're looking at using amps with it, this shouldn't be a big deal. Just make your decision based on cosmetics, design, ease of use, and features.
    However, this does make me dislike Panasonic and like Kenwood a lot more. I don't like it when manufacturers make the limiting factors in a test so narrow that it renders the results meaningless, just to make the figures more impressive.
    -5 for Panasonic
    +1 for Kenwood
    However, despite the manufacturers different attitudes, this shouldn't directly affect you much since you're using external amps.
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    [Car Audio]
  • MacLeod
    edited July 2005
    Both these measurements are irrelevent. Both will make about the same power which is about nothing.
    A head unit is a horrible power source. They cant help it, they are limited by their size. Compare a 50x4 head unit to a 50x4 amp. Notice the amp is about 5 times bigger than the h/u? How can the h/u make as much power? It cant. A h/u will only make about 10 watts real world. Anything beyond that will be quite dirty.
    So choose your head unit by features, looks and price. The amp sections are going to be identical, at least as far as youll be able to hear.
  • Toxis
    Toxis Posts: 5,116
    edited July 2005
    a lot of companies (even in the home audio world, cheap **** of course) rate their amplifiers at 1k frequency because it's the easiest frequency for an amplifier to play, thus will give more power than it will at say 20 or 20k. More power rated means better for advertising... but in the mobile audio world, how many "popular" companies HONESTLY rate their amps accurately? Popular usually rolls with bling... let that be enough said.
  • exalted512
    exalted512 Posts: 10,735
    edited July 2005
    toxis, is there as much crap in the HT world as there is in CA? i dont really think so because CA is geared more towards kids and kids are more susceptible to bling and the like...
    -Cody
  • swerve
    swerve Posts: 1,862
    edited July 2005
    -Cody
    you mean this nitro flip down LCD i bought wasn't worth 100 dollars?
    man I knew something was fishy....
    cats.vans.bag...
  • MacLeod
    edited July 2005
    Well in the car audio world, most quality manufacturers underrate their amps signifigantly. A 100 watt amp from MTX, Crossfire, PPI and the like will likely be a 150+ watt amp.
    From what little experience Ive had with home audio, the opposite seems to be true.
  • audiobliss
    edited July 2005
    Now, wait a minute. What amps have you had experience with in the HT world? If you're talking about Sony, Yamaha, Denon, Onkyo, JVC, etc, that doesn't count. MTX, Crossfire, PPI are 'good' CA amps; you have to also look at 'good' HT amps. If you look at NAD, B&K, Carver, Anthem, Rotel, Sunfire, etc, I'm sure they'd be underrated just as much as the previously mentioned CA amps.
    And of course since we're talking about amps, that excludes receivers; we're now talking separates.
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    [Car Audio]
  • exalted512
    edited July 2005
    i dont know much about home audio, but i do know some of the amps you just listed are much better than mtx and crossfire are in the CA world...
    -Cody
  • MacLeod
    edited July 2005
    -Cody
    To some people anyway.
    :rolleyes:
    I admit to not having much experience with seperate HA amps. Im basing my opinion on home receivers boasting 120x7 and barely making 50x7. At least car audio h/u's rate their 50x4 as "peak". HA receivers try to pull this 120x7 crap off as RMS!
    VR3 Posts: 28,774
    edited July 2005
    Seperate Amps and Receivers are completely different animals.
    Most seperate amps in HA are overbuilt at any price point, from 100 to 40,000
  • neomagus00
    neomagus00 Posts: 3,899
    edited July 2005
    hmm... i happen to use a 5-channel rotel separate amp... i'll have to go home and take a peek, see if it's telling the truth...
  • audiobliss
    edited July 2005
    I thought you said you were outta the HA world? Man, a 5-channel Rotel...sweet. What is it driving?
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    [Car Audio]
  • neomagus00
    edited July 2005
    nah, i'm not out, i'm just not expanding at the moment. the one i have is driving stand-mounted B&W fronts and center, and Bose direct/reflect surrounds. it is fed by a rotel reciever and both are conditioned by a rotel line conditioner.
  • MacLeod
    edited July 2005
    Definitely do that Neo!
    Ive read several reviews on receivers and seperate amps in home audio magazines and Ive never seen an actual "tested power". Im curious as to how they perform.
  • Mendo
    Mendo Posts: 13
    edited July 2005
    how well would the Kenwood KAC-7202 amp work for polk mmc6500? im going to use the Panasonic CQ-C9700U cd player
  • MacLeod
    edited July 2005
    It would work like a charm.
  • audiobliss
    edited July 2005
    Looks to me like it'd do just fine.
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    [Car Audio]
  • Mendo
    Mendo Posts: 13
    edited July 2005
    sorry i need more help
    the deal going on at crutchfield says that if you spend $399 on polk/momo stuff you get a free 10" momo sub or pay just $20 and get a 12" momo sub
    now i was thinking of putting in a single 15" polk sub but now with the deal im thinking of going with the single 12" sub. the other thing is that with the 15" you can get a q-logic box for only $10
    can you tell me if there is a big difference between the two subs or not
    thanks
  • ND13
    ND13 Posts: 7,601
    edited July 2005
    thanks
    Historically, 12" subs are more accurate than 15" subs. Now with that being said, things have progressed since my days in the car audio scene, so that may not be true anymore. It'll depend on how you like your bass. I prefer 10" subs in sealed enclosures, but that's me.
    "SOME PEOPLE CALL ME MAURICE,
    CAUSE I SPEAK OF THE POMPITIOUS OF LOVE"
  • MacLeod
    edited July 2005
    It depends. 500 watts thru a single sub will sound just like 500 watts thru 2 subs (250 each). Its the total watts used that make the difference, not the number of subs.
    I dont like 15's. Theyre the loudest but I prefer 12's if the sub is going to be in the trunk and 10's if the sub is going to be in the cab with me like in a hatchback or SUV.
