Old Amp Need Help!!! New
Hogdawgs
I HAVE A OLD MARANTZ AMP MODEL 8 I THINK. I JUST GOT FROM MY GRANDFATHER, ITS OLD
MIGHT SELL IT OR KEEP NOT SURE HOW IT WORKS
Post edited by Hogdawgs on
Soo what is the help you need?Skynut
SOPA® Founder
The system Almost there
DVD Onkyo DV-SP802
Sunfire Theater Grand II
Sherbourn 7/2100
Panamax 5510 power conditioner (for electronics)
2 PSAudio UPC-200 power conditioners (for amps)
Front L/R RT3000p (Bi-Wired)
Center CS1000p (Bi-Wired) (under the television)
Center RT2000p's (Bi-Wired) (on each side of the television)
Sur FX1000
SVS ultra plus 2
www.ShadetreesMachineShop.com
Thanks for looking -
HOW DOES IT WORK? WHAT DO YOU HOOK TO IT? IS IT WORTH KEEPING!!!
Sorry about caps
no camera -
First hit on google....
General :
Rarity - Rare
Retail Price - 250
Designed in - USA
Manufactured In - USA
First Year - 1959
Last Year - 1962
Channels - Two
Tube Design - Yes
Speaker Connections - Two sets
Amplifier :
RMS Power Per Channel - 30
Cooling Fan(s) - No
Auxillary Metering - Yes
I am guessing with the right speaker it will sound pretty good, but it does not have alot of value. I would play with it to see if you like the sound and then pass it on (let e-bay set the price for you - don't expect to make much on it though)
There is a model 9 on e-bay, if it is anything like that I would play with it.
Does it have tubes?
What kind of connections can be made on the back?Skynut
SOPA® Founder
DVD Onkyo DV-SP802
Sherbourn 7/2100
Sur FX1000
SVS ultra plus 2
I dont care what its worth really. Its a 8b if that means anything?
has a bunch of glass tubes in front and screws for speaker wire -
If you don't want it let me know, if it powers up and all the tubes glow, I might be interested."SOME PEOPLE CALL ME MAURICE,
CAUSE I SPEAK OF THE POMPITIOUS OF LOVE" -
DittoSkynut
SOPA® Founder
DVD Onkyo DV-SP802
Sherbourn 7/2100
Sur FX1000
SVS ultra plus 2
I just went to classicaudio.com and this is what they have on the amp.
model 8B
type Power
Vintage 1964-1968
Orig $ 285.00
Used $ 1133.00/2056.00
I would say it would probably be worth investing a little money to get this working well. At least I wouldn't just give it away.
