Onkyo B Stock
jeremie
Do you guys see any issues with buying B stock item from Stores if they are discounted? I am looking at buying a Onkyo 602 to replace my Onkyo 787 that broke and I can save 100 bucks by buying a factory sealed B stock reciever vs New non refurbished. Any opinions?
Receiver Yamaha 3070 *Emotiva xpa5 * Behringer iNuke 6000dsp *Monster Cable HTS 3500 -- line conditioner * Panamax 5300 * Apple 4K * Panasonic UB820 * JVC NX5 * Silver Ticket thin bezel 120”
LSIM - Fronts 707 * Center 706c * Sides 702 * Rear 703 *FP RC85i * RP RC65i * Sub (2) SI HT18
Post edited by jeremie on
When i was searching for a receiver, (ended up with a new 502S for 200) a lot of people recommended refurb because a lot of companies have the same warranty. So check the warranty if it's the same then yo shouldn't have a problem with it. Then again there are warranty issues. I might buy a refurb 8211 soon from onkyo so hopefully it works out
Good luck,
ChrisReceiver: Onkyo TX-SR502-S
DVD Player: Pioneer DV-578A-S
Left and Right: R50
Center: CS1
Rear Center: R15
Surrounds: R30
Subwoofer: 10'' Dayton 100 Watt -
Go for it.HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
"God grooves with tubes." -
i bought a onkyo sr-701 for 300 since it was a floor model, and then used the warranty to fix the subwoofer pre-out, which cost me 30 to ship and i had to wait for a month to use my receiver. so my suggestion would be to make sure you can test all the connections when you the b-stock, so that you can use the warranty. i hadnt planned on buying a subwoofer at that time, but did on a whim, and i am glad that i did else i would have never known there was a problem.
Now if I could only find a B stock TX-NR1000.........
I have some B stock and refurbed stuff at home (not Onkyo though) and never had a problem with it.Brian Knauss
ex-Electrical Engineer for Polk -
Bought a onk 602 off of ubid.com refurb job for a family member. Cant find a mark on it works fine, its potluck but so are "new" receivers and pre's. The 602 does not have preouts like your 787 if that matters.
RT1 -
If it's an authorized dealer and still has the warranty, why not?
Ubid has a quantity of refurbed 602s now for $229, ends on the 5th.
Combo rig:
SDA 1C, CS400i, SDA 2B
PB13Ultra RO
BW Silvers
Oppo BDP-83SE -
If it carries the full warrantee, no worry here.
Most of the time, this Monday's "A" stock is next Monday's "B" stock. Buyers remorse creates alot of "B" stock when liberal return policies are used.
I find refurbed, or "B" stock a better deal than floor demos. Less grubby hands and abuse seems to be the factor in my experience.HT Optoma HD25 LV on 80" DIY Screen, Anthem MRX 300 Receiver, Pioneer Elite BDP 51FD Polk CS350LS, Polk SDA1C, Polk FX300, Polk RT55, Dual EBS Adire Shiva 320watt tuned to 17hz, ICs-DIY Twisted Prs, Speaker-Raymond Cable
