"low" vs. "high" power tubes
Early B.
Early B. Posts: 7,900
edited June 2005 in 2 Channel Audio
I've read a number of reviews on tubes and many people claim that the EL34's and EL84's sound more "musical" than their big brothers such as the 6550's/KT88's. Any truth to that?
"God grooves with tubes."
Post edited by Early B. on
  • organ
    organ Posts: 4,969
    edited June 2005
    I heard the same thing but most people use the word 'romantic' to describe the EL34. IMO, the EL34 does sound very romantic. However, I can't say anything about the KT88, 6L6, etc. Never heard them. EL34 seems to be the most popular output tube.
    Maurice
  • RuSsMaN
    RuSsMaN Posts: 17,987
    edited June 2005
    The 6L6 family in general, are good music tubes. 6L6, 807, EL34, 7591, 7868 etc. The 6550 was built for audio, and it shows in the sound.
    All things equal, push pull, I'd say the more relevant factor is the Iron used, not the tubes.
    Cheers,
    Russ
  • Early B.
    edited June 2005
    Russ, are you referring to the transformers? Can you elaborate?
  • madmax
    madmax Posts: 12,434
    edited June 2005
    I have both the 302A and 502A Jolida amps. The 302A (EL-34) sounds more romantic (specific frequency response) whereas the 502A (6550/KT-88) is more straight forward. I guess I could say the 502A sounds closer to SS in terms of frequency response but still has the high definition of tubes, obviously. At times I like one better than the other. I wont say which because it keeps changing. Just for the record I am using the KT-88's and can't really speak for the 6550's.
    madmax
    Vinyl, the final frontier...
  • Early B.
    edited June 2005
    Max -- what does "romantic" sound like? Is it more laid back? More airy?
  • dragon1952
    dragon1952 Posts: 4,907
    edited June 2005
    I like to use the word 'dreamy'. The sound makes you bat your eyes at your system and want to give it a big french kiss.
  • madmax
    edited June 2005
    Folks, do not try this at home. At least unplug the mains first...
    Dreamy is a great description. In cold hard terms I would explain the sound as bubbly and loose at the bottom, light and airy at the top, slightly bloated around the lower to mid midrange and a little held back in the upper midrange. All in a good kinda way. Nothing like it.
    madmax
    Edit: One other thing. Although almost all listening is done at volume levels without distortion, the EL-34's can sometimes be very nice when they first start going into distortion. Such artists as Jimi Hendrix, some rap stuff and the Beach Boys come to mind when I think of this. It gives you the sense that the music has balls...
  • Early B.
    edited June 2005
    I'm gonna have to hear it for myself. Maybe I'll look for some other high end audio stores in the area that sell tube gear.
    Max -- is there a specific type of music you prefer on the 302 vs. the 502?
  • madmax
    edited June 2005
    Very dynamic stuff is better on the 502. Voice and acoustic or mellow stuff is better on the 302.
    madmax
  • dragon1952
    edited June 2005
    Well if you're not a romantic yourself maybe you wouldn't even recognize it :(
    Signs that you are not a romantic.
    1) Your idea of foreplay is to leaf though the latest issue of Playboy.
    2) Your wife asks you to whisper sweet nothings in her ear and you reply with 'Spread your legs b*tch!"
    3) You get your wife a new bowling ball for Valentines Day.
  • madmax
    edited June 2005
    Don't you have the 502? I'm not sure but I thought there was a simple mod to change it to use EL-34's. Remove some resistor or something simple like that. Maybe something you could switch back and forth.
    madmax
  • organ
    organ Posts: 4,969
    edited June 2005
    madmax
    That's a great word to describe the sound. Just wondering, what EL34 are you using there, Madmax? I find the SED =C= to be the most 'dreamy' of all the EL34 tubes I've tried. I like EH for its lively presentation.
    Also, how do they sound when they start going into distortion? I don't think I ever heard mine do that. But I hear guitarists talk about 'crunch' or something like that. But hifi and guitar is different.
    Maurice
  • Early B.
    edited June 2005
    Max -- I've read on audioasylum that some people have done this mod, but it is not recommended. Has something to do with potentially overloading the transformers or something like that. My own mod guy suggested that I not do it.
