Amp question for mm465's
Systems
I have a Memphis pb600 amplifier that is rated 150W X 2 RMS. Is this a good amp to drive the mm465's? and how do I set it up becouse I don't have any subs.
Testing
Testing
Testing
Testing
Testing
Kim usually reccomends setting the high pass at 80-90 Hz for the MM465's especially if you have a subwoofer. 80Hz is better without a sub, not sure how much lower would be recommended. Are you there Kim?
