All plastic binding posts?
madmax
madmax Posts: 12,434
edited June 2005 in Speakers
I would like to find an all plastic binding post. No metal at all. Has anyone seen anything like this?
It sounds silly at first but what I would like is to run the two wires out of my loudspeaker and thread it through the binding post hole. I would then thread my speaker cable wire through the same holes and tighten the plastic nut to give me a nice crimped connection. This should be the same as having no binding post at all.
madmax
Vinyl, the final frontier...
Post edited by madmax on
  • thehaens@cox.net
    thehaens@cox.net Posts: 1,012
    edited June 2005
    But try these guys..
    http://www.traindoctor.com/Service/Lionel/3600to6300.asp
    P/N: 4045-015
    Orders and Parts: (989) 793-6887
    Call and see if it is all plastic.....
  • madmax
    edited June 2005
    Good thought! Too bad they don't have pics on their site. Actually we have a few hobby stores around here with tons of train parts. I'll check into it. I never thought about a hobby shop.
    Thanks!
    madmax
  • hoosier21
    hoosier21 Posts: 4,418
    edited June 2005
    maybe get some nylon bolts and nuts:
    1. check how much of the bolt will stick out of the speaker cabinet and drill a hole on the bolt.
    2. put hex head of the bolt in the speaker
    3. use one nut on the outside to hold the bolt in place.
    4. place the wires in the hole you drilled, then use a nut to tighten the wires
    Dodd - Battery Preamp
    ADS 1230 - Polk SDA 2B
    Crown K1 - Subwoofer amp
    Outlaw ICBM - crossover
    Beringher BFD - sub eq
  • madmax
    edited June 2005
    Hmmm,
    Make my own huh? Interesting idea. :)
    madmax
