Kenwood DP-M991 CD Player Disc Changer
Jstas
Jstas Posts: 14,996
edited June 2005 in Electronics
Well, I was severely jealous of my father in law when he landed that Sony CD changer from George Grand because it was a diamond in the rough! I set out looking for a similar example of what Sony used to be able to do in the electronics bidness.
I searched to no avail.
Then, about 2 weeks ago, gwh listed this little beauty in the flea market. I purchased it for around $40 shipped to my door. I got it home and started playing with it hooked up to my home grown tube amp and the R15's I picked up from Noel. It performed admirably although the R15's are still breaking in with a large flat spot in the mid-range. It's getting better as time goes on though.
Anyhoo, I hooked this gem up to the SDA rig and it has served to impress! I was worried that it might not match the quality of the dbx player I was using. The main reason I wanted it on this rig was for the changer feature. Well, it's doing very well and has enhanced the depth of the soundstage over the dbx. It's also a bit cleaner than the dbx with a higher line out voltage so the nice strong signal needs little tweaking on the pre-amp to sound acceptable. It did sound better on tubes but this Adcom is working out well. I think the difference is attributable to the Onkyo pre-amp in line. I might pull out the Carver or Rotel to test it out and see if the difference is more pleasing.
Overall though, for a fairly inexpensive CD changer, this Kenwood is indicative of what Kenwood was able to do once, just like Sony. It's a relic of a gone era for Kenwood is no longer making home audio equipment and has decided to focus on the mobile audio and multimedia markets. I hope one day that they get back into the home audio market to make the gear that the quality of thier car audio equipment shows they can make.
Expert Moron Extraordinaire
