Multiple Amp Questions
PolkThug
PolkThug Posts: 7,532
edited June 2005 in Car Audio & Electronics
I'm going to be hooking up a Polk C400.4 (in 75x4 mode) and a Kenwood 7201 (in 460x1 mode). I want to have a nice clean install, this will be going in a 2006 Mustang GT.
Could you use a distribution block for the two amp grounds? Or is that stupid?
Also, what size power and ground wires should I be using?
Any advice will be helpful.
Thanks,
Toby
HU: undetermined
Fronts: Polk MMC5250
Rear: Polk MMC570
Bass: (2) Polk MM2154DVC
Cap: 1farad Monster Digicap
Post edited by PolkThug on
  • swerve
    swerve Posts: 1,862
    edited June 2005
    What gauge power wire are you running.
    You can use a ground distro or you can ground them out to the same place I think (that's what I did and it's not a problem).
    ground out the same awg you used to go into the amps.
    try that maybe.
    cats.vans.bag...
  • PolkThug
    edited June 2005
    So, I'm thinking 4AWG into two 8AWG's.
    ----4
    [distro]===8====
  • swerve
    swerve Posts: 1,862
    edited June 2005
    ----4
    [distro]===8====
    uh huh.
    :D:D
    cats.vans.bag...
  • exalted512
    exalted512 Posts: 10,735
    edited June 2005
    thats what i do, its called a common ground and is very useful
    -Cody
  • swerve
    swerve Posts: 1,862
    edited June 2005
    -Cody
    thanks. couldn't remember what it was.
    even though i don't ever show it here. i can usually figure out wtf i'm doing. lol
    cats.vans.bag...
  • Jstas
    Jstas Posts: 14,845
    edited June 2005
    Usually, with anything bigger than 8 guage wire, it can be difficult to get all your connections connected on one little bolt or nut. So I grabbed an unfused distribution block and mount it so that I can get the shortest run from all amps to the block and then run a 4-2 guage ground wire to my ground point. It depends on how many amps and what kind of power is being run.
    Expert Moron Extraordinaire
  • swerve
    swerve Posts: 1,862
    edited June 2005
    that's why you find a big bolt or nut...
    =D
    cats.vans.bag...
