RT1000p, PSW250, CS400,fx300
Hi all..... I'm new to this forum so HI to everyone here........
I'm doing a major upgrade on my receiver to an Onkyo TX-NR801. My speakers are in good shape "still" but don't know if I should upgrade the speakers too. Any comments welcome.
Post edited by lontar on
Since they still sound good keep em! the only thing that you should consider changing is the subwoofer. Make sure that your receiver has pre-outs so that if you want to add more power via separate amplifers you can.Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2
What are your mains?
Looks like a good start to me.
Upgrading depends on your budget and the size of your room.
I would try it like it is for a while and see what you think.Skynut
SOPA® Founder
The system Almost there
DVD Onkyo DV-SP802
Sunfire Theater Grand II
Sherbourn 7/2100
Panamax 5510 power conditioner (for electronics)
2 PSAudio UPC-200 power conditioners (for amps)
Front L/R RT3000p (Bi-Wired)
Center CS1000p (Bi-Wired) (under the television)
Center RT2000p's (Bi-Wired) (on each side of the television)
Sur FX1000
SVS ultra plus 2
www.ShadetreesMachineShop.com
Thanks for looking -
They are Polk RT1000p
Sub PSW250
Center CS400
Surround RTFX300
Receiver is an Onkyo TX-DS575 - upgrading to Onkyo TX-NR801 with all the nuts and bolts....
Nice receiver, I enjoy my Onkyo alot. I plan to buy something else in the future but for now I really like it.Skynut
SOPA® Founder
DVD Onkyo DV-SP802
Sherbourn 7/2100
Sur FX1000
SVS ultra plus 2
And trust me I finished playing with it and my son told me DAD the couch is trembling...... so I love the new receiver..... the old one might go for sale on ebay.... -
Hi! Welcome to the forums Lontar. If you're happy with your speakers- I say keep them. That's a nice setup. Secondly, does your new receiver have pre-outs? If so- then that's the next step you should do in upgrading. With a new, improved receiver paired up to a set of speakers you already like- Then ADD AN AMPLIFIER to the receiver- trust me- It did wonders for my setup.
Thanks -
for a new amp:
http://www.outlawaudio.com/rules.html
for a pre-owned amp (the best deals)
http://www.adcom.com/
IMO these two manufactorers offer the most amp for the $.
