Sub/Main speaker rolloff
gordonf238
gordonf238 Posts: 15
edited June 2005 in Speakers
I'm using a Velodyne sub and a pair of Polk bookshelves (with 5.25" woofers).
I have my sub's low-pass crossover set to 100Hz, and its high-pass crossover set to 80Hz.
My question is, is 20Hz of a "blend" adequate, or does it depend on personal taste?
My sub's low-pass crossover can go up to 200Hz, but I'm not sure whether that'd be really necessary.
What's your preferred amount of "blend", if you know what I mean by that word, between the sub and main speaker units?
Post edited by gordonf238 on
  • louthewiz
    louthewiz Posts: 581
    edited June 2005
    80 hz all the way for mine.
    My gear,
    Acer PH530 720P PJ
    100 inch Da-Lite Video Spectra screen
    Yamaha HTR 5790
    Toshiba HD-A3
    Denon 1600 dvd player with sdi out,
    DVDO iSCAN HD+
    Panasonic Dmr E-80H
    Dishnetwork HD pvr
    1 Audiosource amp300 150 wpc Fronts
    1 Audiosource ampone bridged 200 watts powering center
    1 Onkyo M-282 105 wpc amplifier sides
    polk cs400 center
    polk RT400 mains
    Polk mkII back surrounds,
    Polk FX300fxi dipole surrounds
    Velodyne DPS-10 sub
    Klipsch KSW-10 sub.:cool:
  • amulford
    amulford Posts: 5,020
    edited June 2005
    I try to keep 20 Hz. No missing info, and I also go as high as possible to ease the load on the mids.
    I do mine in the receiver for the HT.
  • John K.
    John K. Posts: 822
    edited June 2005
    Gordon, one thing to keep in mind is that the numbers on the sub's crossover control(I assume that you don't have a receiver with bass management) frequently are fairly far off from the actual result; e.g. a 100Hz setting might actually take place at 80Hz or 120Hz. Checking with test tones to see the real effect can be done. Regardless of that matter however, no overlapping of the crossover points of the sort that you describe is necessary to get a good "blend". There's no sharp cutoff to the speakers below the crossover point or to the sub above the crossover point; it's just a rolloff. So, if you can accurately set both of the crossovers to 80Hz, there'll be all the "blend" that's advisable.
