A + B speaker output
Willow
Willow Posts: 11,257
edited June 2005 in Electronics
I could not find in the manual if I can use B to power my tweets. What are the chances this can be done? I was playing with the set up and noticed that B can be set to Off, main or zone 2.
I do not beleive my reeceiver has zone 2 (B) has seperate amps, or maybe it does?
Post edited by Willow on
    billbillw Posts: 7,797
    edited June 2005
    Don't bother. The A and B outputs come from the same amps/power supply. In fact, there is usally a warning about playing both at the same time. There will be no audible benefit. There was a long thread a few months ago with a guy trying to quasi bi-amp his LSi15 by using some of the unused channels in his 7 channel Yamaha receiver. In the end, he couldn't hear any difference.
  • Willow
    edited June 2005
    I didn't think I could It's not a top of the line yammie but thought I'd ask. I didn't even see a warning, that's why I thought I'd ask.
  • TrappedUnder Ice
    TrappedUnder Ice Posts: 975
    edited June 2005
    You can do that...but I doubt you will get any benefeit out of doing it. Ive ran both a/b channels off my Yammie recievers for ever. never once had one shut down, get too hot or have any issues. If you want too try..,.nothing really lost but some time.
  • ND13
    ND13 Posts: 7,601
    edited June 2005
    I run my A's and B's together almost daily on my HK, with a 4 ohm set on the A and a 6 ohm set on the B, and have yet to have a single issue, either.
    "SOME PEOPLE CALL ME MAURICE,
    CAUSE I SPEAK OF THE POMPITIOUS OF LOVE"
  • Spawndn72
    Spawndn72 Posts: 453
    edited June 2005
    Assuming the H/K's A&B terminals are wired in parallel (most recievers are) then you are running a 2.4ohm load.
    Setup:
    Adcom GFA-545 amp
    Nad 1600 pre
    Dual 704 TT
    Pioneer 707 R2R
    Pioneer DV-578A Multi-format
    Polk SDA-2 Mains
  • ND13
    ND13 Posts: 7,601
    edited June 2005
    Yep, and since I don't really crank it up when they're playing together, that might be why it hasn't hurt anything. And it also shows that HK conservatively rates not only their power, but also their stability rating, huh.
