Rti 12 : Rxv 2500 : Outlaw 200m
brockmouse1
Hallo again,
I need help????not a audioholic..........
I have new the Yamaha RXV 2500 and new RTI12's as main fronts, and with HT.
from this Forum, to run the RTI12's to there full power, to use OUTLAW 200M MONO BLOCKS...
BUT NOW COMES THE STUPID QUESTION!!!!!!!!!!!!!!
How do I hook up the OUTLAW 200M x 2 to the Yamaha 2500, to play in STEREO and HOME THEATER.
sorry about this stupid question BUT there are so many connections on the back of the Yamaha 2500.
thanks very much.
John(Germany)
thanks very much.
John(Germany)
Post edited by brockmouse1 on
brockmouse1
There should be a set of pre-outs on the back of the reciever just below the RS-232C connection. Connect these to the input jack on the back on the outlaw. Not sure if you have to change any of the recievers settings -
To be more specific if you need, the preout jacks will be right next to the sub preout jack. Use the ones for Right Front and Left Front. Connect one each to either monoblock, and then connect the speakers to the Outlaw amps obviously.
When you turn on your receiver, it will send a signal to your mains via the Outlaws, giving them more power. You will still control playback mode through the Yamaha.Current System:
CSi5-Center (for sale**)
FXi3-surrounds (for sale**)
Martin Logan Depth-Sub
B&K AVR 507
Pimare CD21-CD Player
Denon 1815-DVD Player
Panamax M5500-EX-Line Conditioner -
Hello "brockmouse1" I have the htr 5790 and I have an audiosource amp driving my 2 infinity towers and my hookup is as follows, I rac 1 rca cable from each preamp out on the back of the 5790 to the input of the amp and if your amps have a gain/volume control turn up the gain to max and run the ypao on the 2500 and you will be all set.My gear,
Acer PH530 720P PJ
100 inch Da-Lite Video Spectra screen
Yamaha HTR 5790
Toshiba HD-A3
Denon 1600 dvd player with sdi out,
DVDO iSCAN HD+
Panasonic Dmr E-80H
Dishnetwork HD pvr
1 Audiosource amp300 150 wpc Fronts
1 Audiosource ampone bridged 200 watts powering center
1 Onkyo M-282 105 wpc amplifier sides
polk cs400 center
polk RT400 mains
Polk mkII back surrounds,
Polk FX300fxi dipole surrounds
Velodyne DPS-10 sub
Klipsch KSW-10 sub.:cool:
