Quick...Sub Connect question
Schris22
I currently have a dayon 10 inch sub from Parts express aka the baby boomer or something. It's doing the budget job for now, but the cable that came with it is the standard stero white and red RCA cable. The sub preout on my receiver has only one connector. I've been just hooking up one in from the sub and the only one out from the receiver.... and I'm wondering if I buy one of those 2 to one connectors to hookup to my amp would that make any difference?
Cliffnotes: Sub has two in connections, receiver has one out. Make any difference to get a 2 to one cable?
thanks,
Chris
thanks,
Chris
Receiver: Onkyo TX-SR502-S
DVD Player: Pioneer DV-578A-S
Left and Right: R50
Center: CS1
Rear Center: R15
Surrounds: R30
Subwoofer: 10'' Dayton 100 Watt
Left and Right: R50
Center: CS1
Rear Center: R15
Surrounds: R30
Post edited by Schris22 on
NO.HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
"God grooves with tubes." -
"I'm wondering if I buy one of those 2 to one connectors to hookup to my amp would that make any difference?"
Hi. They're called "Y" adapters.
And yes- they will make a difference but only in volume- by about 3db. i think.
I was going to put Y adaptors. but just wasn't sure so I just went with a description. Thanks guys! clears everything up
ChrisReceiver: Onkyo TX-SR502-S
Left and Right: R50
Center: CS1
Rear Center: R15
Surrounds: R30
