Oh the Joy of tubes
HBombToo
HBombToo Posts: 5,256
edited June 2005 in 2 Channel Audio
just did some swapping... and the left is now working. I knew I was not **** when the change worked... Always keep tubes on hand;)
what a Hobbie:cool:
1/4twin
***WAREMTAE***
Post edited by HBombToo on
  • RuSsMaN
    RuSsMaN Posts: 17,987
    edited June 2005
    You might want to preface with WHY the left wasn't 'working', and perhaps what peice of gear was involved.
    I just pray that it wasn't one of those Amperex EL34's I GAVE you with the Marantz 8b.
    Cheers,
    Russ (two and two thirds saimese twin)
  • organ
    organ Posts: 4,969
    edited June 2005
    Are Ampex, Mullard and Siemens really THAT good or is it mostly hype? I'm blown away by my SED, JJ and EH and can't imagine the EL34 sounding much better.
    Maurice
  • RuSsMaN
    edited June 2005
    Maurice, go back to your hole. They are THAT good. Matched quad of high test Amperex EL34 went out with that amp, go back and read some of Hbomb's initial impressions.
    On that note, you're about to **** your flat hat too, I boxed up your 6DJ8 goodies tonight. You should be so lucky.
    Cheers,
    Rooster
  • HBombToo
    edited June 2005
    Cheers,
    It was the 6FQ7 that bit it...
    Sorry for the late return.
    Russ when you get some time I want to grab an entire compliment of tubes for my Quicksilver and the Marantz.
    HBomb
    ***WAREMTAE***
  • RuSsMaN
    edited June 2005
    Roger that broham.
