Carver Amazing Replacement Woofer Info
F1nut
Since a number of folks here have either the Carver Original Amazings or the Carver Platinum Amazings I thought I'd post this very helpful info on woofer refoam and OEM replacements.
If you want/need to have your woofers refoamed, contact Roland at:
HiTech Audo
2125 SW 19th St.
Gresham, OR 97080
1-503-618-7605
He also repairs all Carver amps, etc. with OEM parts. Very nice and helpful gentleman.
If you want to buy brand new OEM drop in replacement woofers, contact http://www.dynavox.com/
Click on products, then 12" woofer. The replacement for the Original woofer is Part # SW-1220FL and the replacement for the Platinum woofer is Part # WP-1220. These are the exact same as the ones that came with your Amazings and they only cost $25.00 each.
HiTech Audo
2125 SW 19th St.
Gresham, OR 97080
1-503-618-7605
Post edited by F1nut on
Wow, Those for the original look like the original. Does he build them? I bookmaked the page for sure!
Dynavox makes and sells the new ones, HiTech Audio just does the refoam.Political Correctness'.........defined
President of Club Polk -
Wow, only $25 each for a new one, that seems awfully low for a Carver replacement woofer. I wish Polk sold replacement drivers for that, then I could replace all my drivers if I wanted too."SOME PEOPLE CALL ME MAURICE,
CAUSE I SPEAK OF THE POMPITIOUS OF LOVE" -
Great link, I may buy a couple for an open baffle project anyway.
Dynavox, that's suprising - isn't that pretty much Dynaudio's OEM / raw driver brand?
Cheers,
You can't even buy a refoam kit for $25.
