Please help!
TPB
TPB Posts: 4
edited June 2005 in 2 Channel Audio
Im new to the whole house audio scene and I was wondering what I needed to buy to get me up and running. Right now I have 3 rooms of music (1 pr of RC60i in each room = 6 speakers) and impedeance matching volume controls in the walls. What size receiver do I need to get the most out of these speakers. Do I need a separate amp to push all the speakers of will a standard receiver work alone? I just dont want to buy the wrong thing. I just wasnt sure how you are supposed to wire up 3 sets of speakers and still be able to hear them. Thanks alot for any advice.
Post edited by TPB on
  • organ
    organ Posts: 4,969
    edited June 2005
    I'm no good with this multi-room stuff. I'd use a speaker selector box. You're only going to be running one a pair at a time, right? A receiver should do the job. We need more info. How much are you looking to spend?
    Maurice
  • unc2701
    unc2701 Posts: 3,587
    edited June 2005
    See my response in the basic hookup forum.
    Backburner:Krell KAV-300i
  • Willow
    Willow Posts: 11,076
    edited June 2005
    1 post is enough
