Carver M-1.ot common ground?
warren
I also purchased a Carver M-1.ot and aCarver C-2 Steteo Preamp. Is this a common ground amp that I can use with my Polk 2.3s. Thanks, Warren
Some final words,
"If you keep banging your head against the wall,
you're going to have headaches."
Warren
Warren
Post edited by warren on
my carver m4.0t is common ground, so i would assume the 1.0 is as well. if your 2.3's have a pin blade interconnect, i dont think it needs to be common ground, but wait for the more experienced members here to chime in. (if the interconnect is blade/blade, then yes, you need common ground.)Living Room 2 Channel -
Upstairs 2 Channel Rig -
