help identify speakers
transamz
Which speakers had i bass reflex 4 mids and 2 tweeters with the 3 pin cabeling in the back, i was offered a good price for them but the guy said one mid did not work,would these be worth purchsing. thanks
Post edited by transamz on
You need to be a little more descriptive. Are these Polks? Floorstanders / Shelf?Check your lips at the door woman. Shake your hips like battleships. Yeah, all the white girls trip when I sing at Sunday service.
SDA 1 SRS2? I can't think of any others that fit.HT Optoma HD25 LV on 80" DIY Screen, Anthem MRX 300 Receiver, Pioneer Elite BDP 51FD Polk CS350LS, Polk SDA1C, Polk FX300, Polk RT55, Dual EBS Adire Shiva 320watt tuned to 17hz, ICs-DIY Twisted Prs, Speaker-Raymond Cable
That, and the Monitor 12. He did say bass reflex though, so that kills ALL Polk possibilities (with 2 tweeters).Check your lips at the door woman. Shake your hips like battleships. Yeah, all the white girls trip when I sing at Sunday service.
Monitor 12's have just one tweeter per speaker, at least the ones I've seen.
Something like these maybe? Perhaps he was speaking of a passive radiator?
Two Channel Setup:
Speakers: Wharfedale Opus 2-3
Integrated Amp: Krell S-300i
DAC: Arcam irDac
Source: iMac
Remote Control: iPad Mini
3.2 Home Theater Setup:
Fronts: Klipsch RP-160M
Center: Klipsch RP-160M
Subwoofer: SVS PB12NSD (X 2)
AVR: Yamaha Aventage RX-A2030
Blu Ray: Sony BDP-S790
TV Source: DirecTV Genie -
i have a gut feeling that by bass reflex, he means a radiator. I would assume he came to the pok sight because he at least knows (or knew) that they were polks. If I had to wager a guess by the limited info, i would go with SDA 1 (need way more info to even wager a guess as to the version).
a pic would be a HUGE help here.Living Room 2 Channel -
Schiit SYS Passive Pre. Jolida CD player. Songbird streamer. California Audio Labs Sigma II DAC, DIY 300as1/a1 Ice modules Class D amp. LSi15 with MM842 woofer upgrade, Nordost Blue Heaven and Unity interconnects.
Upstairs 2 Channel Rig -
Prometheus Ref. TVC passive pre, SAE A-205 Amp, Wiim pro streamer and Topping E50 DAC, California Audio Labs DX1 CD player, Von Schweikert VR3.5 speakers.
Studio Rig - Scarlett 18i20(Gen3) DAW, Mac Mini, Aiyma A07 Max (BridgedX2), Totem Mites
