how to use crimping tool???
cowboybebop
ok this is bad but i bought this wire splicer/crimper... linkie
i cant figure out how to use this tool, where do i place the wire and how do I splice them? is there a websight that shows how to use a multi function crimping tool like this?
i must be a moron!!!
Post edited by cowboybebop on
ok i figured out the cutting and stripping part, not sure what the heck the crimping part is or what you're supposed to crimp.
are they talking about crimping a wire? why would that be needed? -
The crimper section of the tool is for crimping solderless connectors to wire(s).
^That's right. It's made to "press" down on the connector and crimp/squeeze the connector into the wires.Pioneer 1018
Polk RTIA5's
CSIA6
RC80I's
SVS PB12-nsd
