sub cable/ interconnect
opus
Hello, I have a question about cables.
I am in need of a y connector to hook up my amp to my center channel.
Can I use a mid/high quality sub y cable to do this? What is the difference between a sub cable and a regular cable?
Just wondering if I can save a trip to the store.
thanks.......kevin
thanks.......kevin
The Flea rig
Hitachi 50VG825 LCD
Rotel RSP 1066 (pre) -flea market
B&K St-202 (mains)-flea market
Carver M 200t (x2) (center and surrounds)-flea market
Blu-Ray..PS3 (dvd player)
Polk RTA-11t-flea market
LsiC, Fxi30's
Dual SVS PC-Utra's (1 port blocked) thanks MikeC78
Behringer Feedback Destroyer-flea market
AudioAlchemy DDE v1.0 DAC-flea market
Cambridge Audio Azur 640 CDP-flea market
Signal Cable and Kimber Kable
Hitachi 50VG825 LCD
LsiC, Fxi30's
Post edited by opus on
Sub cable should work. -
I know the difference with the sub cables at Blue Jeans Cable is that the cable has better shielding and rolls off high frequencies. (two different issues, not a cause and effect)
Many sub cables are the same as normal RCA's with better shielding so you may get lucky and have no adverse effects.
It should work in a pinch especially for a center channel. If you like the results - keep it. If not, get another one.
I hate to say it, but the only decent y cables I have seen available locally (except DIY) was monster. I think you can order decent y cables from cobolt cables as well.
It'll work. It's just an RCA cable.HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
"God grooves with tubes." -
there is absolutley no difference between a normal interconect and a sub cable.. The only difference that was already mentioned above is that some of sub cables have more shielding on them becasue they are normally going greater differences. Besides that.... regular old single core conductor with rca terminations
has anybody taken apart various cables to see if they indeed have more shielding?MY HT RIG:
Sherwood p-965
Sherwood sd871 dvd
Rotel 1075 amp x5
LSI15 mains
LsiC center
LSIfx surround backs
Lsi7 side surrounds
SVS pb12/plus2
2 Channel Rig:
nad 1020 Pre-amp
Rotel 1080 stereo amp
Polk sda 2B
kenwood grunt Tuner
realistic lab 450 TT
Signal cable IC -
i have taken apart several differnt cables from monster. i have taken apart a 2m analog audio cable, a 1m digital coax, and a 12' subwoofer cable.
They actually all had different levels of shielding, the coax having the most and then the sub cable and then the analog audio cable. -
As per comment above that is why I use coax for all my IC's, only cause I can buy AR pro II dig coax for 10$
IMO the best cable to use for all of your interconnects is some RG6Q that is rated for direct burial..... You will not find any better shielding then this
All of my cables in both my rigs (except speaker cable) is RG6Q with MCM rca terminations -
I used a fairly high quality car audio RCA cable for my sub, mainly because it's about 22 ft from the receiver, and I couldn't/wouldn't spend a couple of hundred $'s to get one that long. I have been pleasantly surprised with it's performance, so far. Some of the car audio cables are very well suited for home applications, also, IMO. They have to deal with alot of interferences that home gear doesn't. Just my .02."SOME PEOPLE CALL ME MAURICE,
CAUSE I SPEAK OF THE POMPITIOUS OF LOVE" -
hey nd13 just out of curiosity what was the brand of cable you used
It was one that I had from my car audio days(late 80's/early 90's), I'd like to say Phoenix, but it might have been Precision Power. I ran PPI amps with JL subs, I think they made cables also, I've burned up alot of brain cells since then. I'll take a looksee at it tonight to see if it's labeled.
I do know that it has a foil shield in it also."SOME PEOPLE CALL ME MAURICE,
Thanks to everyone for the responses. I do have it hooked up and have found a nice improvement when combined with the new/used Carver that I just got.
On a side note; 2 flea market purchases and 2 flawless transactions. Very nice. Thanks to the sellers and the "F.M. police" who keep everyone in line and watch out over rookies like myself.
kevinThe Flea rig
Hitachi 50VG825 LCD
LsiC, Fxi30's
