Component vs. S-Video
Guys,
I was just wondering if anyone could explain the difference in PQ from the component to the s-video input for dvd. I know that it will be better on the component input, but how much better? Any input would be greatly appreciated.
Landry
Main Set-up: 55" 120 hz Samsung LN55B650, Onkyo TX-SR806, Emotiva XPA-5, Emotiva XPA-2, PS3 Slim, Sony BDP-S560, Apple TV (160g), Panamax M5300-PM, Polk Audio CSi5, RTi10's, FXi3's, RTi4's, and SVS PB12 Plus
Bedroom: Panasonic 50" S2 Plasma and Panasonic BD65 blu-ray player, Onkyo TX-SR707, Emotiva XPA-3, Emotiva UPA-2, KEF IQ7's, IQc, IQ8Ds, and SVS PB10-ISD
Post edited by landry_p2000 on
Welcome!
    edited June 2005
    from what I've heard...
    RCA/Composite to S-video is a huge jump. (I agree)
    S-video to Component not so huge. (don't have any component cables yet.)
    Also kinda depends on how nice your TV is I assume. If you have a really crappy tv than I don't think the difference will be noticable. But probably don't have the worst TV.
    Good luck
    Anyone else think cables are expensive?
    Chris
    Receiver: Onkyo TX-SR502-S
    DVD Player: Pioneer DV-578A-S
    Left and Right: R50
    Center: CS1
    Rear Center: R15
    Surrounds: R30
    Subwoofer: 10'' Dayton 100 Watt
    edited June 2005
    From what I hear the s-video sends the picture in two signals 1 is B&W and the other is color.
    The component sends the signal in 3 different signals like the primary colors and is the better way to go.
    Skynut
    SOPA® Founder
    The system Almost there
    DVD Onkyo DV-SP802
    Sunfire Theater Grand II
    Sherbourn 7/2100
    Panamax 5510 power conditioner (for electronics)
    2 PSAudio UPC-200 power conditioners (for amps)
    Front L/R RT3000p (Bi-Wired)
    Center CS1000p (Bi-Wired) (under the television)
    Center RT2000p's (Bi-Wired) (on each side of the television)
    Sur FX1000
    SVS ultra plus 2
    www.ShadetreesMachineShop.com
    Thanks for looking
    edited June 2005
    ok.... i think i can clear this one up for yha
    First to understand how the cables send the signal you need to know the two things that need to be present in order to display a video signal.
    You need the chromanance (the shade of a particular color) and the lumanance (the brightness of a particular color) of all three primary colors.
    Composite Video:
    composite cables just have a single conductor that sends both the chromonance and the lumanence of all the colors down a single line leaving it to the tv to decode this information and get the right chromanance and lumanance matched up with the right color. Video being such a high bandwidth application it is nearly imposible for the tv to keep up with all the decoding. you can easily spot decoding errors on things like striped patterns where there seems be diagnoal rainbow colors going through them. This is the tv putting the wrong chromance with the wrong colors. You can also see errors when you see two seperate colors that come to a hard line but dont really seem to have a hard line but actually several colors right there in the middle.
    S-Video:
    s-video corrected these decoding errors by having two lines going down the wire instead of one. one line is for the chromance of all the colors and one for the lumanence of all the colors. This really makes it easier for the tv to interpret all of the different information because there is not so much crosstalk going on and errors are few and far between so you get a more accurate pictre
    Component video:
    now component video on the other hand has three indviual wires one for each color. each wire carries the chromance and lumanance for that particualr color so there is no decoding errors done by the tv because there is no decoding to be done. It simply takes what it is given by the lines and puts it up verbatim on the screen. absolutley no errors.
    so as you can see in the end yes there is a big jump in picture quality going from composite to s-video. There is not so much of an improvement when going from s-video to component (when viewing 480p or less material) because s-video is already almost dead accurate. What makes component so much better is the higer bandwidt that is offered by the three indidual lines for all the colors. That is why you have to use component cables to view anything above 480p becasue of the extra space that is required.
    edited June 2005
    Thanks a million guys. That definetly clears it up for me. I am getting an HDTV cable box Friday, and I will hook it up with component cables to get the best PQ possible.
    edited June 2005
    edited June 2005
    BrentMcGhee
    Very good explaination, I had heard it explained that way before but could not remember all the terms.
    Skynut
    SOPA® Founder
    DVD Onkyo DV-SP802
    Sherbourn 7/2100
    Sur FX1000
    SVS ultra plus 2
    Thanks for looking
    edited June 2005
    Of the three types of cables, only component will carry an HDTV signal, so there is no choice here. Composite and S video won't do it.
    Larry
    edited June 2005
    FYI, S-video will not carry a progressive picture, only interlaced. That's another huge jump for Component.
    edited June 2005
    If you are getting HDTV from Comcast they will include component cables with the install. They are of low quality (I kept losing one signal) so You may want to upgrade them, if you have problems.
    edited June 2005
    I got the HDTV box and it is pretty cool. I have my dvd player on the component 2 input and my HDTV box is on component input 1. I love it.:D
    My service is through Time Warner (Memphis), and it came with the component cables and audio cables. I also hooked up the digital out (coax) to the Onkyo. What a difference it makes when you can watch tv shows and movies from HBO, Cinemax, etc. in Dolby Digital 5.1 or Pro-Logic II. The box is a Scientific Atlanta HDTV tuner. Glad to make the change.
    I also like the sound that coax gives in 5.1 DD surround. The receiver I own has only one coax input, and that sucks. It doesn't matter anyhow since my Xbox and Panasonic dvd have optical outputs only.Thanks for helping me to better understand the video side of things fellas.:)
Welcome!
Welcome!
