Opinions on good Toslink
steveinaz
steveinaz Posts: 19,538
edited June 2005 in 2 Channel Audio
I need a good quality well built (minus the snake oil) Toslink cable. Any suggestions? (yes, it needs to be a Toslink).
Post edited by steveinaz on
  • tryrrthg
    tryrrthg Posts: 1,896
    edited June 2005
    I bought a DH labs D-75 digital coax to run from my transport to DAC and I like it so far. DH labs is supposed to make great cables for the money. it would be worth a try to check out their toslink (heck you might even want to give the D-75 digital coax a spin while you're at it.)
    First link is DH labs web site, second link is ACI's web site, they sell DH-labs cable for the best prices I could find.
    http://silversonic.com/docs/prod/
    http://audioc.com/accessories1/dhlabs/toslink.htm
  • dkg999
    dkg999 Posts: 5,647
    edited June 2005
    The Outlaw Audio was the best constructed I found and at a reasonable price point. It did make a change in the sound versus a lower end Monster Cable product, and for the better. I still don't understand why as was pointed out in these forums its all digital info., so the impact on SQ should have been zilch!
    DKG999
  • steveinaz
    edited June 2005
    I've got a D-75 RCA/BNC running from the CDP, now I need a Toslink for the Polk XM tuner. Cool, I didn't know DH Labs sold an FO cable. Thanks brotha
    keep'm comin'
  • ND13
    ND13 Posts: 7,601
    edited June 2005
    Why have I read here, that one shouldn't use the optical cable?I've always heard the opposite
    "SOME PEOPLE CALL ME MAURICE,
    CAUSE I SPEAK OF THE POMPITIOUS OF LOVE"
  • steveinaz
    edited June 2005
    I believe the thinking is why go thru the light conversion process. With coax you take another circuit out of the way.
    What I'm doing is running multiple sources into 1 DAC. My DAC has 3 digital inputs (well, 4 actually):
    BNC (or SPDI/F w/ an adapter)
    Toslink
    AES/EBU (XLR)
    My CDP is on the BNC input, the Polk tuner will go on the optical input (Toslink). I can switch between inputs on the DAC front panel. Very cool.
  • tryrrthg
    edited June 2005
    keep'm comin'
    Cool, I thought you bought a Signal Cable digital coax. I have yet to compare any digital cables to my D-75, but I don't feel the need to right now. I should probably try out a toslink cable and see which sounds better... if you do buy the DH labs toslink let me know what you think between the two.
  • steveinaz
    edited June 2005
    I had an AES/EBU from Signal cable, but it was too short for the new install, so I figured I'd go ahead and get coax this time. You get into CDP's with XLR, and you're into some bucks. Thinking about future upgrades, and how the next CDP will most likely not have AES/EBU.
    heiney9 Posts: 25,221
    edited June 2005
    Steve,
    FWIW consider checking here. If you see something you like, order it from Amazon, they are cheaper...plus anything over $25 is free shipping
    ***edit***
    Found the correct link:
    http://www.cablestogo.com/
  • steveinaz
    edited June 2005
    ok, thanks bud.
