Fx's
Hey I just have to comment on these Fx's. I am using them as surrounds with lsi'9s up front. My center is a Lsi also. Right now I am using my onkyo 989, and a new sunfire is on it's way for 5.1. The sound is incredable. It goes all around the room. I was concerned about the size of the Fx's with the size of my room. Not no more they are awsome. Can't wait to open them up with my new amp. Thanks for all your advice on the lsi line. Doug
Oppo bdp 93 Blue Ray
Integra DTR-80-2
Polk LSi9s (mains)
Polk LSiC (center)
Polk LSiFXs (surrounds)
Sub SVS 20-39+
Samsung 60" Led 3-d
Blue Jean Cables
Integra DTR-80-2
Polk LSi9s (mains)
Polk LSiC (center)
Sub SVS 20-39+
Samsung 60" Led 3-d
Blue Jean Cables
Post edited by doug lang on
i'm glad you are happy with your fx's..... in then end no matter what you buy it always comes down to if your happy with it or not.
I bet you will have some fun with that sunfire when it arrives. -
Glad to hear it. That Sunfire will take 'em where they've never been before. You're gonna luv it. But those 9's will absolutely come alive with some good juice poured into them.
Keep us informed.HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
"God grooves with tubes."
