Separate Amp for Mains Question
Obviously a new speaker package is a ways off for me, but one of my considerations is a nice pair of towers for my mains. I'm considering a separate amp for two-channel, using the preouts on my B&K 507, and using the receiver for the center and surrounds. My question is, do those of you who use a separate amp for your mains find that they are significantly louder than your center and surrounds, especially if the amp outputs more watts than the receiver?
The separate amp is more a consideration for music rather than movies, but I want to make sure it doesn't throw off the soundstage during movie playback. Thoughts?
Current System:
CSi5-Center (for sale**)
FXi3-surrounds (for sale**)
Martin Logan Depth-Sub
B&K AVR 507
Pimare CD21-CD Player
Denon 1815-DVD Player
Panamax M5500-EX-Line Conditioner
B&K AVR 507
Post edited by gregure on
It shouldn't be much different since the preout is sending the same signal that is processed by the receiver's amps... with the seperate amp you will just have a lot more headroom. BTW I've never done this I'm just going by similar experiance with preouts so I could be totally wrong here.
It normally only makes a difference when your receivers amps give up the ship, and the external amp rolls on. Sensitivity on amp's inputs are pretty similar.HT Optoma HD25 LV on 80" DIY Screen, Anthem MRX 300 Receiver, Pioneer Elite BDP 51FD Polk CS350LS, Polk SDA1C, Polk FX300, Polk RT55, Dual EBS Adire Shiva 320watt tuned to 17hz, ICs-DIY Twisted Prs, Speaker-Raymond Cable
gregure
What Amps are you looking at. I was considering this same upgrade? -
As a matter of fact, it was just the opposite. Once calibrated it was seamless. Then I had to boost my center channel up in order to hear dialog for movies.Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2
I have this type of setup and sometimes feel this is a problem. I have an Outlaw M200 for the center but a beefy pro-audio amp for my mains. Even after calibration, I always feel I can't hear dialogue easy and explosions are overwhelming. Night-mode turns out to be a nice feature
But, the cause could be any number of issues (proper calibration, placement, weak Lsic, etc.). So who knows.
I too have to boost the center channel. -
Depends whether the gain/ sensitivity on the power amps is about the same across channels. If you get a B&K power amp it'll probably be spot on, otherwise, get a spl meter, you'll have to tweak.Gallo Ref 3.1 : Bryston 4b SST : Musical fidelity CD Pre : VPI HW-19
Backburner:Krell KAV-300i -
It's not an issue to be concerned about.
That's what calibration is for. And that's why you have a wide range of setup options in your receiver for 2-channel and multi-channel listening.HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
"God grooves with tubes." -
Thanks for the advice guys. It looks like the volume output from the mains would be an issue but that with some tweaking I would have no problems. That's pretty much what I thought.
I'm not sure which system I'm going to get. Either a package from Vienna Acoustics or Sonus Faber. I'm waiting to see what the new Domus series are like.
If I go w/ Vienna, I'd probably get a B&K Ref 200.2 for two-channel. If I go w/ Sonus, I may get a Primare two-channel amp. Perhaps their 3-channel would solve my problem for the front stage, but I really don't feel I need a separate amp for the center. As I said, it's more for two-channel music.Current System:
B&K AVR 507
Panamax M5500-EX-Line Conditioner -
Wow, you got some great options you're looking at. Vienna or Sonus -- tough choice. Let us know what you decide to get.
Even though 2-channel is your main interest, I would suggest separate amplification for the center channel as well. At one point I had an amp for my fronts and no amp for my center channel, but when I got an amp, it definitely took the dialogue and dynamic sounds up a notch to better match the fronts. Not a major priority, but at least something to consider.HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
It's going to be at least a year before I buy, something to save up for. I work at a dealer, so I'll get a great deal on the equipment.Current System:
B&K AVR 507
