Good CAD program?
AsSiMiLaTeD
AsSiMiLaTeD Posts: 11,728
edited April 2024 in Clubhouse Archives
I'm starting a new hobby...building stuff. My primary goal is to learn how to build things and work with wood, secondary goal is to do this without losing any fingers or other body parts...
Anyway, we started with something small this weekend, a sub box. That went okay, made a few first time mistakes along the way that won't happen the second time.
However, one thing I learned is that I'd like to have a decent program that I can use to draw up simple diagrams. I got the job done with a pencil and scratch paper this time, but would like to have something better going forward.
I know of AutoCAD, I've seen the program used in my step-dad's shop where they build airplan tools and such. I know that program will work, but I think it's overkill for what I'm needing.
Does anyone know of a simple CAD program that I can use to draw up things like boxes, cabinets, bookshelves...little things like that?
I'm not going to be doing anything complex anytime soon, so something simple will probably work the best...
  • Spawndn72
    Spawndn72 Posts: 453
    edited June 2005
    Autocad is pretty much the standard in 2D CAD. They do have an LT version which functions pretty much the same, just a few less features; most of which you would probably never use. Both might be expensive for your use however.
    At one time there was a program called intelicad that was pretty good. It was released to public domain. Since then people have picked up the "engine" and expanded on it and are selling it. I did find a link to the public domain version which is Intellicad 2001.
    http://www.simsystems.com/products/intellicad.htm
    Try it at your own risk, I did not check it out.
    Setup:
    Adcom GFA-545 amp
    Nad 1600 pre
    Dual 704 TT
    Pioneer 707 R2R
    Pioneer DV-578A Multi-format
    Polk SDA-2 Mains
  • AsSiMiLaTeD
    edited June 2005
    I have free access to either version of AutoCAD should I choose to go that route...hoping to find something I don't have to learn how to use, something a bit more intuitive.
    I'll check out that intellicad link, thanks.
    I also found a program called DeltaCAD that seem to be what I'm looking for...gonna try that as well...
  • michael_w
    michael_w Posts: 2,813
    edited June 2005
    I use an older version of autocad to do my drawings. (autocad r14) It's a little hard and slow at first to figure out the basics of how to draw something but once you get the hang of it it's pretty nice.
    billbillw Posts: 7,500
    edited June 2005
    AutoSketch or QuickCad are stripped down versions of AutoCad that are somewhat easier to use. I think they quit making QuickCAD though.
  • Grimster74
    Grimster74 Posts: 2,577
    edited June 2005
    If you really want to get fancy, let me know. Not supposed to ;) but I may be able to get you a copy of Architectual Desktop. I have four licensed copies of AutoCad at my house and yes they are licensed in my name.
  • gmorris
    gmorris Posts: 1,179
    edited June 2005
    If you want to spend some money, the undisputed King of ALL CAD systems, Pro/Engineer, can be purchased in the Student Version, for I think about $250.
    Of course, this is a very complicated, in depth 3D modeling software. I use it everyday all day here at work. My understanding is that the Student Version has all the basic functions, but is not compatible with non-student versions.
    Assuming you don't want to spend that kind of cash, I would agree with those who suggested AutoCAD (or AssCAD as we call it here at work). I haven't used AutoCAD for about 7 years, but it is not hard to use at all.
    I have already done this for another forum member, and I'll offer you the same deal. If you tell me the basic overall dimenions of whatever you are designing, I can model it in Pro/E, then create 2D drawings, export them as .PDF's, and email them to you. Free of charge. I like to do that kind of stuff, and if I can help out a forum member, even better.
    Bob Mayo, on the keyboards. Bob Mayo.
  • AsSiMiLaTeD
    edited June 2005
    Awesome, I may take you up on that if I don't end up with AutoCAD. I'm leaning towards that because I can get it for free, I've heard that it's difficult to use though...we shall see.
  • gmorris
    edited June 2005
    No problemo....
    It sounds like there are quite a few of us here that can use AutoCAD, so I'm sure we could help you figure it all out. I'm sure one of us could even draw up a simple box drawing and email it to you, so you could get an idea how things are done.
    One more option I have, I could draw up your design in Pro/E, then export the drawing in AutoCAD, that way you could modify it later, if you needed.
  • Jim Shearer
    Jim Shearer Posts: 369
    edited June 2005
    In my last venture into design (couple years back,) I used a program called TurboCAD.
    --Disclaimer: I'm an analytical chemist (infrared spectroscopist) doing a wide variety of consulting work; no engineering background.--
    TurboCAD is much cheaper than AutoCAD, but suited my needs--design a sampling accessory for infrared spectroscopy that a machinist could then manufacture. The 2-D version was easy to use. The 3-D version I couldn't manage w/ a mouse--ended up hand calculating spacial points & typing them in--clumsy way to do it, but the result was good (helped make sure the machinist made exactly what I had evnisoned.)
    Cheers, Jim
    A day without music is like a day without food.
  • gmorris
    edited June 2005
    Cheers, Jim
    :eek: :eek: Did you use an abacus to do those calcs?
    Just kidding around, I can't imagine calculating & manually entering points. 3D CAD has certainly come a long way.
    And by the way, welcome to the forum....:)
  • Jim Shearer
    edited June 2005
    Never learned to use an abacus, but I still occassionaly use a slide rule (almost as ancient) to calc gas milage when I fill up my car.:D (can't seem to manage to do 3 significant figure division in my head any longer--brains may be going, but my ears are still good, thank heaven!)
    Cheers, Jim
