Njoe Tjoeb 4000
ohskigod
ohskigod Posts: 6,505
edited June 2005 in Electronics
i'm genuinly considering pulling the trigger on this. all the homework i've done seems to indicate it would be a good choice (including what people have told me here in the past).
its either that or the Cambridge audio 640 Azur.
if i go for the Ah!, it seems the only place i can get it is upscale audio.com how are they? reputable? never heard of them before.
thanx for the help.
Living Room 2 Channel -
Upstairs 2 Channel Rig -
Post edited by ohskigod on
  • dragon1952
    dragon1952 Posts: 4,917
    edited June 2005
    They've got a good rep at Audiogon. Feedback rating of 240 .... 80 pos, O neg.
    BTW, did you also consider the Jolida JD-100? Just wondering.
    heiney9 Posts: 25,497
    edited June 2005
    Don't have any experience w/ upscaleaudio.com. I'd go with the Ah! over the Cambridge. The Cambridge is a very capable unit, but the Ah1! is better. The Jolida would be a good choice as well
    Good Luck
  • polksda
    polksda Posts: 716
    edited June 2005
    I bought my Tjoeb 4000 directly from Upscale Audio. No problems whatsoever. Had it about 5 months now. Very helpful folks.
    Advice: spend the extra for the upsampler. It's a phenomenal upgrade.
    F1nut Posts: 51,997
    edited June 2005
    Either the Ah! or the Jolida would be a great choice, both are better than the Cambridge.
  • ohskigod
    edited June 2005
    I'm really stretching over my budget for the Ah, but it seems to be worth it. cant stretch for the ad on's yet, but it seems i can at any time (very upgradable). The Jolida looks nice, but i had enough trouble stretching to the Ah's price point, and the jolida seems to be bit higher.
    thanks for the feedback, especially on the upscaleaudio sight.
    I'll keep you posted when i act either way.
    F1nut Posts: 51,997
    edited June 2005
    Lou, check Audiogon for both, used price for the Jolida has been running between $400 and $600. The Ah! is harder to come by, but they do pop up.
  • dragon1952
    edited June 2005
    Which translated means "If I'd wanted your damn opinion on which CD player I would have asked!" :D
  • ohskigod
    edited June 2005
    LOL, nah, if i wanted to shut out the CD player opinions, i'd tell ya :D
    in all seriousness, i allways here people chime in about the Jolida, it must be a fine CD player. I've never used audiogon, hence my reservation (i'm bad with new things sometimes)
    i might surf around and see what i can find.
    again, i'll keep ya posted.
  • ohskigod
    edited June 2005
    allright, for those that are interested, i checked audiogon for the Jolida, and found a post for the Jolida JD 100A from Underwood Hifi. thay had over 5000 on feedback rating, which seems pretty good. i left a message and Wally called me back in like 2 minutes. He said 780 shipped for a silver Jolida. Since this is right where the price for the Njoe Tjoeb was, i pulled the trigger immediatly
    let the comments commence :D
    seriously, I assuming i made a good move here, I figured the chance to get it new made me feel a little better.
