4 ohm vs. 8 ohm
edited June 2005 in Speakers
Aside from power considerations, is there a reason why one would prefer a 4 ohm speaker to an 8 ohm speaker, or vice versa? Is there a preference for sonic reasons?
Thanks.
"God grooves with tubes."
Post edited by Early B. on
Welcome!
    edited June 2005
    As modern speakers go why did we go from 16 ohms to 8 ohms, just because of Solid State vs. Tubes? So why 4 ohms not 8 ohms is a good question as some speaker as we know are 4 ohms. I can see the reason in car audio for the lower impedance, but then we don't really feel that car audio is really clean. Car audio may not need to be clean due to road noise issues, so why the lower impedance in home audio? I always felt that some speakers are 4 ohms due to the need for a flatter audio curve that some crossovers are designed for this causing the lower impedance.
    All in all a good question.
    Speakers
    Carver Amazing Fronts
    CS400i Center
    RT800i's Rears
    Sub Paradigm Servo 15
    Electronics
    Conrad Johnson PV-5 pre-amp
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
    Sony CX400 CD changer
    Panasonic 42-PX60U Plasma
    WMC Win7 32bit HD DVR
    edited June 2005
    Generally, lower Ohm speakers have more sophisticated (read: expensive) tweeter technologies than 8 Ohm speakers. The 4 Ohms tend to be silk tweeters, ring radiators, ribbons, transducer films, and electrostatics, although there are some variations that run at 5 or 6 Ohm nominal impedance. It's not to say that 8 Ohm aren't as capable of producing quality music playback, but the reality is that most truly high end speakers are 4 Ohm. They have a different sound, and almost always require expensive gear to run them properly, although some 4 Ohms sound pretty good on lesser products such as Denon, HK and Onkyo receivers in the $800-$1200 range. Again, I say lesser in comparison to high end gear, such as separates or receivers that retail for $3000 or more.
    All in all, higher end speakers with such tweeters as listed above tend to be less bright, more tonally balanced, and have tremendous imaging and detail. However, for movies the 8 Ohm, metal dome tweeter speakers seem to still be the best fit, although there are obviously different levels of quality within that range as well. In my experience, though, you will almost never see a metal dome tweeter (aluminum, titanium, etc.) that runs less than 8-6 Ohms nominally.
    Current System:
    CSi5-Center (for sale**)
    FXi3-surrounds (for sale**)
    Martin Logan Depth-Sub
    B&K AVR 507
    Pimare CD21-CD Player
    Denon 1815-DVD Player
    Panamax M5500-EX-Line Conditioner
    edited June 2005
    Greg,
    I know of some high end speakers that use metal dome tweeters. Can you name a couple that use silk? I am just curious, thanks.
    edited June 2005
    All the speakers from Vienna Acoustics use silk tweeters, as did the entry level Sonus Faber, although those are now being replaced with ring radiators, which is what SF uses for all of their other speakers.
    M&K also uses soft domes, although, since they are so geared toward movies in the retail models, they tend to be brighter than other soft dome speakers.
    Martin Logan obviously uses electrostatics, but their entry level and on-wall speakers use transducer film for tweeters and mids.
    The new Summit electrostatic from Martin Logan israted at 4 to .7 Ohms (!) for the highest frequencies.
    Obviously the LSi line uses ring radiator, thus the 4 Ohm impedance and the frequency on the forum of discussing how they need more power to sound good.
    Current System:
    B&K AVR 507
Welcome!
Welcome!
