Building a sub box
AsSiMiLaTeD
AsSiMiLaTeD Posts: 11,728
edited June 2005 in Car Subwoofer Talk
Okay, I need some of you freaks over here in the car forums to help me out:D
We're looking to build a box for my friend, he now has the MM12 in the box Polk made for it, but he's got an '02 Silverado and that thing won't fit under his back seat, so we get to make him a new one, a sealed enclosure is that we're looking at. This is a first for me, and I have a couple questions:
1 - Any tips on sealing the box? What's the best thing to use (Silicone?), and is there any trick to doing this?
2 - Do we need any kind of internal bracing in the box? I wouldn't think so given the small size, but need to be sure.
3 - I assume we'll need some type of filling for the inside. How much, what's the best stuff to get, and how do we install that?
4 - It looks like the cubic feet is .66, that sound about right? What will be the effect of going over or under that amount? I assume it's better to have more air space than not enough?
Any other tips, bring 'em on. If there's a website reference that covers most of this, feel free to share that as well.
Thanks for your help guys.
Post edited by AsSiMiLaTeD on
  • exalted512
    exalted512 Posts: 10,734
    edited June 2005
    get an account at www.fullsizechevy.com would be my best advice. They have box plans and such but you have to be a member to view their threads.
    -Cody
  • MacLeod
    MacLeod Posts: 14,358
    edited June 2005
    Bracing the box is never a bad idea. You cant have too sturdy a box.
    You dont really need polyfill. If the box is built to spec you wont need it.
    Ive always just used a **** load of wood glue to seal mine with but if you want something more Id say run on down to Lowes and look around at all the different types of sealant.
    .66 sounds a bit small especially for a 12. In comparison, the MM2104 (10") only uses .66. Might want to look into that. Building a box too small will mutilate your SQ.
  • AsSiMiLaTeD
    edited June 2005
    Oops...looks like it should be .88.
  • MacLeod
    edited June 2005
    Aha! I knew it!!
    Boy I impress myself sometimes. Im right even when I dont know it!! :p
