rx-v2500 v. DENON 3805
BrettSelinsky
BrettSelinsky Posts: 49
edited June 2005 in Electronics
I bought a rx-v2500 about 3 mo. ago. Went there to buy the 3805 and the salesman talked me into the yammy. Well when I hooked it up it did sound better than what I was used to. But after reading reviews, forums etc. all over the net I really am not satisfied that the yammy was the right choice. I went to my a/v store today and asked them to borrow their 3805 floor model so I could just put the issue to rest. They said I could swap the recievers if I preferd the 3805. I thought this was very impressive for a store to do this with an electronics product that has been used for 3 mo. straight! I'll let you know how it turns out. I cant wait. I hope the Denon kicks its a**. Not because its Denon over yammy. Just that my system will sound better.
Speakers
Fronts: RTi70's
Surr: R50's
Center: PSB
Sub: Def Tech (dont even know what I own)?
Brett Selinsky
Denon 3805
Denon DVD/CD
Crown ProAmp
JVC VHS
RTi70's Front
CSi5 Center
R50's Rear
DefTech Sub
Post edited by BrettSelinsky on
    heiney9 Posts: 25,507
    edited June 2005
    Sounds like a win/win situation. You really can’t go wrong if you are going to compare them side by side. In the future don’t let the reviews and comments make you believe you may have made a bad choice. Sometimes I drive myself crazy lamenting over reviews and comments by others. This is especially frustrating AFTER the purchase. It seems after I read this or that and then sit down and listen to my system, a big smile still comes over my face and I realize I have it pretty damn good. J It could always be better but it could also be worse.
    Have fun with your shoot-out and post your impressions
  • aaharvel
    aaharvel Posts: 4,489
    edited June 2005
    If the Denon doesn't kick the Yammy's **** in sound quality- i'll be very surprised.
    H/K Signature 2.1+235
    Jungson MagicBoat II
    Revel Performa M-20
    Velodyne cht-10 sub
    Rega P1 Turntable
    "People working at Polk Audio must sit around the office and just laugh their balls off reading many of these comments." -Lush
  • JDSMOKE
    JDSMOKE Posts: 31
    edited June 2005
    I have the yamaha and love it. I tried both and with my speakers the yamaha sounded better. Don't worry about what you read just be concerned with what sounds good to you with your system.
    http://www.audioholics.com/productreviews/avhardware/Denon-AVR3805_review01.php
    http://www.audioholics.com/productreviews/avhardware/YamahaRX-V2500review01.php
  • Early B.
    Early B. Posts: 7,900
    edited June 2005
    I'll put my money on the Yamaha.
    "God grooves with tubes."
  • AsSiMiLaTeD
    AsSiMiLaTeD Posts: 11,728
    edited June 2005
    I'm a Denon guy myself...never card much for that bright Yamaha sound...but if you like it that's all that matters...
    edited June 2005
    I'll put my money on not much of a difference. But the comparison has to be scientific. Blind tests at EXACTLY the same output level's, same listening position, same source and material, etc., etc. It also needs to be done over time. You should give it more than an hour also. A few days minimum.
  • shiu
    shiu Posts: 169
    edited June 2005
    If you A/B the two, you may not be able to tell the difference. If you do a double blind test, I am almost sure you cannot tell them apart. Most likely the 3805 is more powerful. Its a good deal if you are getting a new one. For one thing, the 3805 costs more.
  • BrettSelinsky
    edited June 2005
    Its only been 4hrs (wifes flippen) but the dennon is winning big time. I finally know what warm sounding is. The only problem i might have is the bass. My daughter is sleeping so I cant crank it up to see what it does. I like every kind of music but rap (sorry to those of you that do) and everything has been awesome on the Denon at moderate levels. I put Dave Mathews in and heard shi- I never heard before on his CD's.(SAX MOSTLY). MY WIFE EVEN SAID SHE LIKES THE DENON BETTER??????????? I just dont think the bass is as tight and that is what I like. I'll pop in the Metallica and Godsmack Thursday and let you know my decision. As for DVD it sounds pretty much the same. But from a music standpoint I think the Denon is alot better!!!! And if I do switch, I owe it to you guy's/gals and the guys/gals at audioholics. Thats what made my mind to--- free my mind of my wondering if I made the right decision and persue this. Oh and it is more user friendly and the remote is sweet. The speaker hookups are a pain vs the yammy. So I'm gonna get bannna plugs.
    Newbie
    Brett Selinsky
    Denon 3805
    Denon DVD/CD
    Crown ProAmp
    JVC VHS
    RTi70's Front
    CSi5 Center
    R50's Rear
    DefTech Sub
  • fireshoes
    fireshoes Posts: 3,167
    edited June 2005
    Make sure you run the auto setup on each unit as well, since the distance and eq settings will have a big effect on the sound.
  • Toxis
    Toxis Posts: 5,116
    edited June 2005
    Denon all the way...
    well unless you really enjoy listening to music in "German Bathroom" or "Swedish Toilet" sound modes.
  • gregure
    gregure Posts: 871
    edited June 2005
    Read a backdated issue of Sound and Vision not too long ago on the Denon 3805. They also addressed the slightly muddy sound to the bass, but also stated that they were able to clean that up quite a bit with the unit's EQ. If you are happy with the sound overall, sounds like you've got a winner. Tweak the EQ, or have a friend who knows how come over, until you have the bass where you're happy with it. Receivers are just like TV's. They have a certain level of quality out of the box, which can then be tailored to a particular room, customer, etc.
    And I don't think the blind comparison would be that close. Yamaha is much brighter, in my opinion, just like Pioneer Elite. There is a big difference in sound between PE and Denon, and I find Denon to be much better for music. The 3805 is a great product, take it and don't look back.
    Current System:
    CSi5-Center (for sale**)
    FXi3-surrounds (for sale**)
    Martin Logan Depth-Sub
    B&K AVR 507
    Pimare CD21-CD Player
    Denon 1815-DVD Player
    Panamax M5500-EX-Line Conditioner
  • marker
    marker Posts: 1,084
    edited June 2005
    :D:):p;) :cool: My first AVR was a Yamaha, can't even remember what model it was, but it had something like 24 different soundfields, Church, disco, stadium, Kelly's pool hall, etc.
  • BrettSelinsky
    edited June 2005
    Denon 3805 is the winner hands down. The bass seems to be the same as the Yammy in my opinion. Hoping to tweak the EQ like the previous poster stated and make it even better. The sound is so much more pleasing to my ears. (And my wifes? If she can tell a difference then thats something!
    Brett Selinsky
    Denon 3805
    Denon DVD/CD
    Crown ProAmp
    JVC VHS
    RTi70's Front
    CSi5 Center
    R50's Rear
    DefTech Sub
  • AsSiMiLaTeD
    edited June 2005
    Cool, glad you're digging the new receiver...
  • Toxis
    Toxis Posts: 5,116
    edited June 2005
    Glad to hear you kept the Denon over the Yammie. Damn fine decision if you ask me. ;)
  • aaharvel
    edited June 2005
    "well unless you really enjoy listening to music in "German Bathroom" or "Swedish Toilet" sound modes"
    bravo Toxis.
    You can tell an average receiver from a great one by comparing the two with 2ch. music, not dolby 5.1. Obviously comparing with music is what won him over to the Denon. I knew it would.
    Revel Performa M-20
    Velodyne cht-10 sub
    Rega P1 Turntable
    edited June 2005
    Congrats.................and oh btw, welcome to the disease. You've got it now and there's no getting rid of IT. :eek: :eek:
  • BrettSelinsky
    edited June 2005
    And I think I have it bad?
    Brett Selinsky
    Denon 3805
    Denon DVD/CD
    Crown ProAmp
    JVC VHS
    RTi70's Front
    CSi5 Center
    R50's Rear
    DefTech Sub
  • cfrizz
    cfrizz Posts: 13,415
    edited June 2005
    Welcome to the club. Congrats on your purchase! and 2 new receivers in 3 months time? Yeah you have it bad!!!:D
  • SuperDave
    SuperDave Posts: 168
    edited June 2005
    Just throwin my two cents in. I've had my RX-V992 for years and no problems. It has had a lot of hard use running home theater and I listen to 2 channel in the no effects mode. Its all subjective to the sound you like, but I can vouch for longevity as well.
    SuperDave
    Yamaha RX-V992
    Panasonic DVD-A310
    Sony XBR 27"
    DVR
    Polk LSI 25 Fronts
    Infinity CC3 Center
    Infinity RS1 Rears
    Monster THX Cables
    SuperDave
    Yamaha RX-V992 (Center,Rears)
    Adcom GFA-5500 (Mains)
    Denon DVD-1920
    Mitsubishi 40" LCD
    DirecTV DVR Whole House
    Polk LSi25 Mains
    Polk LSiC Center
    Infinity RS1 Rears
    Monster THX Cables
  • MSALLA
    MSALLA Posts: 1,602
    edited June 2005
    SuperDave
    Yamaha RX-V992
    Panasonic DVD-A310
    Sony XBR 27"
    DVR
    Polk LSI 25 Fronts
    Infinity CC3 Center
    Infinity RS1 Rears
    Monster THX Cables
    I second that. I have 3 yamaha recv. over the last 22 years and they all still work just like new. I know alot of people here don't like the Yamaha's but I have tried a Harmon Kardon AVR and it was a bad unit so I got gun shy. I'm not saying I don't like Denon. I just think that Yamaha's (except the HTR line) make a great unit.
    I keep reading on here about the WATT ratings and that Yamaha rates at 1KHz but thats only true for the HTR line. The rest are 20-20,000 with all channels driven.
    Michael
    Samsung 50" HD DLP
    Yamaha RX-V2500
    (2) Outlaw 200
    Adcom GFA 555
    Sony BDP300
    Denon 2900 DVD
    Lsi9's mains
    Lsi7's rear
    Lsic center
    12.1 SVS driver in 4.53 cuft. tube
    Harmony 880
