Break-in Recommendations
markmarc
markmarc Posts: 2,309
I haven't purchased new speakers since 1980 (all have been demos or used). Back then just sending white noise (volume 50%, from a turned off source) was enough to break the speaker in. Does that still apply or do I need to actually play music?
Former Staff Member TONEAudio
2 Ch. System
Post edited by markmarc on
  • Skynut
    Skynut Posts: 2,967
    edited June 2005
    I do not know, when I got mine I just cranked them up till I was tired of loud music and then I turned them down till the next good song came on.
    Are you supposed to break them in?
    Skynut
    SOPA® Founder
    The system Almost there
    DVD Onkyo DV-SP802
    Sunfire Theater Grand II
    Sherbourn 7/2100
    Panamax 5510 power conditioner (for electronics)
    2 PSAudio UPC-200 power conditioners (for amps)
    Front L/R RT3000p (Bi-Wired)
    Center CS1000p (Bi-Wired) (under the television)
    Center RT2000p's (Bi-Wired) (on each side of the television)
    Sur FX1000
    SVS ultra plus 2
    www.ShadetreesMachineShop.com
    Thanks for looking
  • aaharvel
    aaharvel Posts: 4,489
    edited June 2005
    it's a natural process that just takes time- much like buying and driving a brand new car. Don't be rough with it the first 5,000 miles- just do normal driving. I wouldn't blast a new speaker at high volumes with any genre of music. To get the new tweeter and to a lesser extent the midrange to calm down a bit and not be so straightforward and bright I would usually play more mellow music- This took about 60-80hrs. of playback on my set.
    In the end though I don't think it's so much the type of music you play on the new speaker as much as it's HOW you play the music on your new speaker.
    H/K Signature 2.1+235
    Jungson MagicBoat II
    Revel Performa M-20
    Velodyne cht-10 sub
    Rega P1 Turntable
    "People working at Polk Audio must sit around the office and just laugh their balls off reading many of these comments." -Lush
