Yamaha rxv 540
Willow
Willow Posts: 11,232
edited June 2005 in Electronics
thia is the receiver I am using. when watching movies everything sounds great until we get to a scene where an explosion or heavy bass, we find we must turn doen the receiver. Is this dur to the fact the receiver does not have enough power or is this just how everyone elses system is.
Post edited by Willow on
  • Willow
    edited May 2005
    Bump....
    anyone ?
  • AsSiMiLaTeD
    AsSiMiLaTeD Posts: 11,728
    edited May 2005
    why do you feel like you have to turn down the receiver? Is it distorting or just too loud? If it's too loud, it's just doing it's job. If it's distorting that's different...
    What speakers are you using?
  • Willow
    edited May 2005
    Polk thanks for the reply, it's too loud !!
    rti8
    rti4
    csi3
    energy s10.2
  • AsSiMiLaTeD
    edited May 2005
    Yep, it's supposed to be loud...as long as it's not distorting you should be fine.
    However, some receivers and DVD players have something like a 'night' mode that reduces the dynamics of movies...you may want to check into that and see if you've got that somewhere and turn it on.
    I personally don't care for it because dynamics add a lot to sound (it's one of the four properties of sound after all - pitch, timbre, duration, and dynamics), but it'll decrease the volume of those explosions and such...
  • Spawndn72
    Spawndn72 Posts: 453
    edited May 2005
    it's too loud !!
    Then your to old :)
    Sounds like the reciever is doing just fine.
    Setup:
    Adcom GFA-545 amp
    Nad 1600 pre
    Dual 704 TT
    Pioneer 707 R2R
    Pioneer DV-578A Multi-format
    Polk SDA-2 Mains
    billbillw Posts: 7,551
    edited May 2005
    Explosions are supposed to be LOUD! That is the way that the director/sound editor wanted it to be. Modern movies strive for realism.
    If you don't like the sound effects that loud, try using the compression feature in your setup menu (usually in the Dolby Digital area). Yamaha might have another name for it like Night Mode or something. It will make the quiet scenes louder and the loud scenes softer so that there is less dynamic range. Purists scoff at these settings though.
  • Willow
    edited May 2005
    ok. I don't mind it loud and it's not at all distorted, I have never heard distortion on this system.
    We have attached neighbours and people who live upstaires garden homes/terrace homes.
    I will try the night mode ( don't want to). Maybe I could try night mode and beef up the bass a tadd.
    What about the dynamic range it's set to max I wonder if it's set to standard if this will make a difference.
  • Airplay355
    Airplay355 Posts: 4,298
    edited May 2005
    if you have the dynamic range cranked up (i didn't even know there was a dynamic range setting) then that is your poblem.
  • AsSiMiLaTeD
    edited May 2005
    Yeah, dynamics are good, but you don't want to overdo it. I'd change that from max to standard and see how that works for you...
  • Willow
    edited June 2005
    Yamaha has three settings, max(for movies) standard(for Tv) and the last one(can't remember).
    I will do that tonight to see if it's better. last night I was having issues with my dvd player
  • SuperDave
    SuperDave Posts: 168
    edited June 2005
    If you have the range set to MAX you will get a large difference between dialogue and action. Try the MIN setting and you will not get such a loud difference with the action. It is the setting I use for all my daughters sleepovers when I do not want to be awakened by explosions or worse.
    SuperDave
    Yamaha RX-V992
    Panasonic DVD-A310
    Sony XBR 27"
    DVR
    Polk LSI 25 Fronts
    Infinity CC3 Center
    Infinity RS1 Rears
    Monster THX Cables
    SuperDave
    Yamaha RX-V992 (Center,Rears)
    Adcom GFA-5500 (Mains)
    Denon DVD-1920
    Mitsubishi 40" LCD
    DirecTV DVR Whole House
    Polk LSi25 Mains
    Polk LSiC Center
    Infinity RS1 Rears
    Monster THX Cables
  • Willow
    edited June 2005
    Thanks I wacthed incredibles again on STD setting and was much better. I may try the MIN but I am affraid it will be to little.
