freq response question
what happens when you set a 100 or 120hz speaker to 80? just curious if it will damage. I'm pretty sure it wont sound good right? thanks
Post edited by baboon on
it defeats the point of a crossover because the speakers can't play the low frequency anyway. it would probably only damage the if you had it at high volumes. otherwise it wouldn't be much different then sending them the full range signal.
Yeah, it's no different than sending a full range signal. Not many speakers are full range anyway. The speakers crossover will do the work.2 channel - Willsenton R8 tube integrated, Holo Audio Spring 3 KTE DAC, audio optimized NUC7i5, Windows 10 Pro/JRiver MC29/Fidelizer Plus 8.7 w/LPS and external SSD drive, PS Audio PerfectWave P3 regenerator, KEF R3 speakers, Rythmik F12SE subwoofer, Audioquest Diamond USB cable, Gabriel Gold IC's, Morrow Audio SP5 speaker cables. Computer - Windows 10/JRiver, Schiit Magni 3+/Modi 3+, Fostex PMO.4n monitors, Sennheiser HD600 headphones
setting a 100hz speaker to 80hz will sound fine. For a 120hz speaker- you should set the crossover at 100hz. You have to keep in mind that with both speaker internal crossovers and the crossover in your pre/pro there's still a roll-off- sometimes as little as 6db per octave.
The rule of thumb Polk customer service told me was as long as the crossover in your processor is set within the vicnity of
+/-20hz of your speakers bass limit then you'll be fine.
