SDA Tech question for Polk
madmax
I have the old SDA-SRS model which I want to use the isolation xformer with. Blade-blade model. I know, you can't put it in the cable. (I have a recommended 1:1 xformer from Newark) Can it be wired into the xover? I'm technically competent if someone can give me a clue. I really want to use these speakers with non-common ground amps. Really...
Thanks,
madmax
Thanks,
madmax
Vinyl, the final frontier...
Post edited by madmax on
It turns out that a non-common ground turned out to not be my problem. In any case I would still prefer to set my SDA-SRS speakers up for non-common ground amps. Please reply if you have any info on this.
Thanks,
