Surge Protection, Filtration what would you recomend
comet91
comet91 Posts: 56
edited June 2005 in 2 Channel Audio
be reading a lot the last couple of day on this. just want to get some feedback on what some other people use.if you can give links please.
thanks
comet91
Post edited by comet91 on
  • bknauss
    bknauss Posts: 1,441
    edited May 2005
    Just got a PureAV (Belkin) PF60 last week. Works pretty darn well.
    Brian Knauss
    ex-Electrical Engineer for Polk
  • Skynut
    Skynut Posts: 2,967
    edited May 2005
    I use a Panamax 5510 and it is built like a tank.
    Look it up in your search browser (sp?) and check it out.
    The thing I like is it has a lot of weight which tells me something is in there and it has a light that can plug into the front or back.
    I use it in the back all the time when I am working back there.
    It seems to work real well, I do not hear anything but what I am supposed to hear.
    Totally happy.:D
    Skynut
    SOPA® Founder
    The system Almost there
    DVD Onkyo DV-SP802
    Sunfire Theater Grand II
    Sherbourn 7/2100
    Panamax 5510 power conditioner (for electronics)
    2 PSAudio UPC-200 power conditioners (for amps)
    Front L/R RT3000p (Bi-Wired)
    Center CS1000p (Bi-Wired) (under the television)
    Center RT2000p's (Bi-Wired) (on each side of the television)
    Sur FX1000
    SVS ultra plus 2
    www.ShadetreesMachineShop.com
    Thanks for looking
  • unbridled_id
    unbridled_id Posts: 179
    edited June 2005
    Brick Wall Surge Filters, PW8R15AUD, 15 Amp, 8 Isolated Receptacle Point of Use Unit for Audio Use.
    The greatest enemy of truth is very often not the lie - deliberate, contrived and dishonest - but the myth - persistent, persuasive and unrealistic.
    Blaming the prince of the fools should not blind anyone to the vast confederacy of fools that made him their prince.
  • dkg999
    dkg999 Posts: 5,647
    edited June 2005
    The Panamax and Tripp Lite conditioners/surge suppressors are reasonably priced and work great! I have a Panamax 4310, Tripp Lite LCR-2400 and Isobar Ultra 8, and an Adcom ACE-515. The new Belkin one's look interesting.
    DKG999
  • Early B.
    Early B. Posts: 7,900
    edited June 2005
    Yep. TrippLite Isobar.
    "God grooves with tubes."
  • pearsall001
    pearsall001 Posts: 5,094
    edited June 2005
    EQUITECH - Son of Q
    Once you see & hear what balanced power does for your rig, you'll be scratching your head in disbelief thinking that somebody switched out all your gear when you weren't looking. An awesome piece!!
