CS400i too much?
Ron Temple
Considering picking up a CS400i. Is this too much speaker for my system?
Onkyo HT R-520
R50s fronts
R15s surrounds
Thanks for the advice.
Onkyo HT R-520
R50s fronts
R15s surrounds
Combo rig:
SDA 1C, CS400i, SDA 2B
PB13Ultra RO
BW Silvers
Oppo BDP-83SE
Post edited by Ron Temple on
No. Since it carries most of the sound and all of the dialogue, the center channel should be the first purchase on the road to Upgradesville. Afterwards, pick up some fronts -- RTi or Monitor series -- and put your current fronts in the rear. Then get a kick-**** sub. Then replace your rears. Then upgrade your interconnects and speaker cables. By then it'll be time for another receiver or separate amplification. Then you'll be as crazy as the rest of us...HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
"God grooves with tubes." -
I just knew you were going to say that. I had put aside this "hobby" for over 20 years and my first marriage. My current wife bought me an Onkyo 770 for Xmas. I was pretty pleased for what it was for movies, but I started to listen to music again. I bought some R30s for my son. Had to check them out first and so the upgrade slope started. The R50s went on sale, then the 15s. Gonna snag a center, a new sub and receiver.
Don't even talk to me about RTis or LSIs until I get my first stage finished.
The CS400i will suck alot more power than my other speakers. I'm just concerned that I'll have an unbalanced front soundstage with what I presently have.
Combo rig:
PB13Ultra RO
BW Silvers
Oppo BDP-83SE -
Onkyo HT R-520
R50s fronts
R15s surrounds
If you are buying the one on e-bay, be aware that he ran that same add earlier and supposedly sold both.
Cs400i
Cs400i
Same add different end dates.
Ask questions and pay in person.Skynut
SOPA® Founder
The system Almost there
DVD Onkyo DV-SP802
Sunfire Theater Grand II
Sherbourn 7/2100
Panamax 5510 power conditioner (for electronics)
2 PSAudio UPC-200 power conditioners (for amps)
Front L/R RT3000p (Bi-Wired)
Center CS1000p (Bi-Wired) (under the television)
Center RT2000p's (Bi-Wired) (on each side of the television)
Sur FX1000
SVS ultra plus 2
www.ShadetreesMachineShop.com
Thanks for looking -
Thanks - I'll look into to it. I did see the same items twice.
Combo rig:
PB13Ultra RO
BW Silvers
Oppo BDP-83SE
