Phono Question
candyliquor35m
Would playing/installing/setting my turntable directly on top of a high power amp (375 wpc) such as a carver tfm-45 be a problem because of all the static electricity the turntable can generate?
Can I ground the turntable to the amp chassis?
Post edited by candyliquor35m on
I don't think I would set anything on top of my amp. My integrated amp is approx. 140 wpc and it gets hot enough to fry an egg when I'm running it in Class A mode. As far as the static is concerned I doubt it would be a problem, but that's just my opinion.
I no longer have my turntable connected, but I believe there is a connection on my amp for the turntable ground.2-Channel
Amp: Parasound A21
Preamp: Parasound P3
Polk LSi9s
Polk SDA-Compacts (on standby)
Sub: Polk PSW404
CD: Sony -
I wouldn't, due to the heat trap.
If static is that bad, on your TT, I would look into some tweaks to reduce the static. Static adds to the pops on your lps if not controlled. Try different mats, cleaning cloths, or for $40 bucks you can buy a Zerostat type device to zap your system. They work great.
Ionoclast
This version from Mapleshade works great!HT Optoma HD25 LV on 80" DIY Screen, Anthem MRX 300 Receiver, Pioneer Elite BDP 51FD Polk CS350LS, Polk SDA1C, Polk FX300, Polk RT55, Dual EBS Adire Shiva 320watt tuned to 17hz, ICs-DIY Twisted Prs, Speaker-Raymond Cable
I have a 20 year old zerostat gun and will try it. My carver amps all stay completely cool so heat won't be a problem. Thanks.
Ok...now I'm really interested. What are the stats on your amps? Cool at that wattage?2-Channel
Amp: Parasound A21
Polk LSi9s
Sub: Polk PSW404
CD: Sony -
I used to run the carver tfm-45 fairly consistently with the volume at 3/4 on my preamp but I had the preamp digital attenuator set to -10 dB so I don't know what that translates to. Some others may chime in here but my carvers virtually generate no heat no matter how hard I push them.
when i crank it my carver gets hot, otherwise its just slightly warm.
